Aftermarket Shocks for Trooper
dude47
The back right corner of my trooper is starting to sag. Think my dad worked it a little hard on the whoops and blew out the shock. Does anyone have a resonably priced set up they used for aftermarket shocks? I can't justify putting 3k worth of shocks on a machine I only paid 4k for used lol.
Thanks for your input in advance!
Pretty sure but not positive about these numbers for the fronts, less sure about the rears, if you are seriously considering FOAs, I'll check harder to get you the right numbers and more info about what I have.
Qty. Item Name Unit Total
Reservoir Shocks 2.5 FRONT SHOCKS
size - FOA-06
Compression Valve - Light/Medium
Rebound Valve - Light/Med
Mount width - 1.5"
$150.00 $150.00
Reservoir Shocks 2.5 REAR SHOCKS
size - FOA-08 ?????? maybe 10 inch
Compression Valve - Medium
Rebound Valve - Medium
Mount width - 1.5"
$155.00 $155.00
2.5" Springs FRONT SPRING
size - 2.5x14x200
color - Black
$49.00 $49.00
2.5" Springs 1 OF 2 REAR SPRING edited corrected
size - 2.5x10x400
color - Black
$49.00 $49.00
2.5" Springs 2 OF 2 REAR SPRING edited corrected
size - 2.5x10x600
color - Black
$49.00 $49.00
Dual Rate Spring Hardware REAR SPRING SEPARATOR
size - 2.5 shock
collar/crossover -
$25.00 $25.00
Sub-Total: $477.00
I put on Fox Shocks $ 1000, Coil Springs $ 300 from Off Road Warehouse with 1 free revalve.
Fox Shox 2.0 X 6.5 Coil-over Remote Reservoir Shock
  • Shaft: 5/8'' (.625)
  • Finish: Black / Zinc
  • Ext. Length: 19.35
  • Col. Length: 12.85
  • Reservoir: 2.0 X 8.0
  • Hose: -5 X 12.0
  • Mounting: 1/2 X 1.250
Fox Shox 2.0 X 8.5 Coil-over Remote Reservoir Shock
  • Ext. Length: 23.35
  • Col. Length: 14.85
  • Hose: -5 X 12.0
How well does your trooper do on whoops and bumpy hard pack? I am very interested in going with foas. They are reasonably priced. Also I have gotta ask how you made your rear fenders?
During this bad weather, (winter), I just reworked the front shocks to have more rebound dampening and haven't had a chance to try them, but I'm sure they are as good as any other shock, way better than stock, and you can rebuild them. The rears were doing quite well, but the front had too little rebound dampening and I have just fixed that, I hope, but need to test it.
I'll have to take some photos of my fenders for you, but the plastic came from http://www.speedwaymotors.com/in the form of a 10’ or 25' X 22" X 1/8” rolls (http://www.speedwaymotors.com/Colored-Plastic-Rolls-25-Ft,31414.html ) and the frame work is a piece of 1" X 1/2" channel iron bent around the tire and supported by 2 1/2" square tubes and stabilized at the front.
photos later today, hopefully.
Amy modifications for mounting them.
  • Hose: -5 X 12.0
  • Hose: -5 X 12.0
My whole air shock setup cost me about 1300-1400 rides Awsome can't power slide though without body roll but I like it a lot
Good to hear. They have been trying the new air shocks on the Supercross bikes and they have not preformed as well as the old setups. Most of the riders have returned to there old setups siting lack of feel in the air shocks.
rocmoc n AZ/Mexico
Ya Rocmoc I really like it, air shocks are coming a long way and over the weekend I watched a show called xtreme 4x4 and theres these new off road airstrutts coming out its almost like a dual rate air shock with lots of adjustment not with just pressure but valving and they also cut the wieght down. Im gonna try post the link when I think to watch it again. What the latest with the JEEPS
  • 2 years later...
  • Hose: -5 X 12.0
  • Hose: -5 X 12.0
You mentioned two different sets here. I take it the bottom info is for the rear shocks?
    • By goindeep
      Well now i could use a lil help... i have a trooper in my shop now that has wiring issues... this poor guy paid another shop $1000 to re wire the body control harness, and boy oh boy did they chop it up!!! I am Buillding a new harness from scratch... what i need is a diagram that tells me what each fuse and relay control on the Engine fuse/relay block.. any help is greatly appreciated!!
      Josh
      No Limitz
    • By lowgear52
      Does anyone out there have a rear differential for a trooper for sale?
    • By Kingfish
      I've had a battery failure and need one replacement.  The local distributor told me it might take up to four weeks to get one.  I'd like to order one in sooner than that if possible.  Any help would be appreciated.
    • By Byron Johnson
      Does anyone have a had time starting there utv.
      I have a T-Boss 750 and I have had to put 2 starters in and put heavier wire to the starter but it still has a problem starting. it will turn over and than die before it wil turn over again. could it be that there is to much compression that might cause this problem
      Thank you
    • By Michael Flippin
      I have a 2023 T-Boss 410. The starter is just spinning but nothing is turning over. It was working fine and just stalled. Tried to restart and starter just spins. Thought maybe the interior of the starter broke. Ordered and installed a new starter and it does the same thing. You just hear the starter spinning but does not seem like anything is catching. I checked the gear the starter engages and that is clean and turning freely. Any idea what the issue could be?
