2005 Mule 610 Ignition Problem
By Dave N.
2020 Massimo Buck 400 - Won't start. Can hear the starter spinning, but motor never turns. Relay? Starter? Worked fine one day and not the next. Thanks for any help you can provide.
By Steve Toney
Hello, my name is Steve and just signing up. Bought my first UTV yesterday. It is a Massimo T-Boss 550.
By SafeSledBryan
Hey guys! My name is Bryan and i am the owner and creator of Safe Sled. Not some crazy corporate backed recovery product, but just some guy with an idea.
4 years ago, I suffered 11 strokes, and am now 50% paralyzed on the left side of my body. I am unable to work a normal job anymore. I was working on the sled 2 years before this all unraveled. My wife told me to keep working on it since i was pissing her off staying home and doing nothing.
I still plan on improving and implementing different ideas as the product’s revenue continues to grow.
if the sled is appealing to you, please check out my website, safesledoffroad.com
Safe Sled Website
By Felderlostnspace
2016, Hisun 500 turns over great but Spark plug is firing when I turn the ignition key on. I’ve got good fuel pressure to the injector. Pulled plug out and it is wet with. gasoline. Air filter is clean. Turns over great just does not even try to pop or start.. I’ve checked off uses and they are good when I turn the key on I’m getting power to the injector.. I’m not hearing the injector pulsing, but may just be my hearing.. With the spark plug getting wet with gas I feel like the injector is pulsing and spraying. Any suggestions would be great. I don’t know the hours on the unit offhand, but it has 600 miles on it. Thank you for your comments and advanced.
By malenurse13
We just bought a used 2017 American Landmaster TW450. No hour meter that I can find, so not sure exactly how much it has been used.
The first 2 days we had it, the starter was a little sketchy, but it started after 2-3 tries. Sometimes when turning the key, we would hear a loud metal "clink" sound. Like the starter made contact, but didn't have enough power to turn.
THIS MORNING... Turning the key, we hear a single click sound. That's it. Even with a new battery, the starter is still doing the same thing. Both batteries (old and new) were reading 12.8 volts on volt meter. So I'm wondering what else could be going on? Any ideas on what to look for would be greatly appreciated...
Thank you!
