2008 Can-Am commado only has front wheel drive
Silverbullet
It could be 2 things 1 the 4x4 switch 2 bad 4x4 actuator.With the ignition switch in the run position when you move the 4x4 switch you should hear a buzzing sound from the front differential switch.If you hear the buzz than the switch is ok.To check if the the actuator is to pull out the 4x4 actuator off. There is 1 screw on the driver side and 1 that you have to remove the tunnel by the shiftier to get to the other screw out.Once you have it out plug in the wiring and move the 4x4 switch take the cover off the actuator and see if the plastic screw moves than give me a call.928 344 2117
Thanks Frankie
    • By Ron from the Mitten
      I purchased a 2008 Qlink Rodeo 700 a few years ago.  I am from Michigan.  Anyone know of any local repair shops?  I had a dead battery, so I replaced that, started right up, ran the quad down the road, (this was last year), put it in the barn, shut it off.  then a couple weeks later, went to go start it again, and nothing.  I have power to the dash lights, horn, turn signals, wench etc, but nothing to the starter switch, and I hate electrical crap.  Battery still reads 12.x volts.
      Any suggestions would be amazing.  I've owned it over 2 years, and haven't run 1 tank of gas through it.  No time to screw with it, and very frustrated.  Hoping someone can offer some advice of value.
    • By alevins
      Good day all,
      searching here but cannot find the answer,  Hisun been working fine and now reverse limiter seems to be engaging and cannot back up, cannot find a clear solution to disable the limiter. found a possible relay?  not sure which one or to cuut a wire at ecu but a picture or diagram would be helpful
      thank you for any help in advance
    • By MJG
      Hello,
      I found an 08 Renegade for sale and looking to purchase it.  I haven’t heard too much about these machines and any insight would be much appreciated.  Are they good machines?
    • By Richard shepard
      I have a 2021 colman 400utv engine will start and idle, as soon as you hit throttle to move engine dies and will only start when you throttle it, let off throttle it dies, I replaced the injector and plug still the same, anyone have any other ideas
    • By Timpiker
      My UTV is a few years old and gets very little use.  I just noticed the drive belt slapping the plastic guard and making some noise.  The manual tells me how to replace it but not how to tighten it.  Apparently, there is no adjustment.  Does anyone know if there is an adjustment?  Is the belt supposed to have a lot of slop in it?
