Trooper loud clunk in front
Jacksnife
I'm having a loud bang in the front every now and then. It sounds like it comes from the left and right wheels (alternately). It doesn't do it on flat road at all, only on a rutted dirt path. At first I thought it was the suspension violently reaching the extent of it's travel, kind of like a no rubber metal on metal bang.
I just got it (used) so it's a mystery how long this bang has been there.
Any ideas?
agreed with Bigdan ...also Quite often you will find loose shock bolts at one or both ends of very stiff sprung shocks..also having stiff front shocks tends to "jarr" or bang the suspension back to the top..there are lots of bolts and joints to bang up there...pay particular attention to the upper and lower balljoint
( the joint itself ,where the joint fits the a arm..and where the pinch bolt joint is) for movement/loose parts...hate to see something come apart ...Hardy
I don't think I have ever pin pointed where it's coming from, but I do think its every little ounce of play in the suspension bottoming out all at once, I still have it after 20,000 kilometers!
I tries using limit straps, not help, It seems like my most productive attempt was to make the front end suspension as lightly sprung as I could, but I have some 200# springs which I think is a bit too much. Seems to happen on rebound.
No, I haven't gone fast enough in 4x4 to even try it. 4x4 all locked is so hard to turn it's basically useless unless I'm in a jam (mud)
It never happens cruising down the pavement. It appears to only happen when one of the front wheels come off the ground. I don't know if it clunks when the wheel leaves the ground or when it hits back on the ground, but it is violent. I would compare it to a 5lb sledge hitting the frame (with considerable force). My steering box is so loose that I'm going to try that first. I'm considering a replacement that might help ease up the 4x4 steering vs just applying the looseness 'fix'.
This might sound dumb but see if you can do a video with sound for us to hear... maybe take pictures of all your front end with tires off...
As far as steering in locked 4x4..
I believe there all like that...
I installed my own electric steering. Can be done now for less then 300.00 if you can fab and weld..
I mean, only when you're in 4x4? if so, it could simply be your diff lock cable is out of adjustment, even if you didn't use the diif lock. the adjustment is finicky and it will clunk loudly every once in a while if the asjustment is out.
Crappy video of steering box play...
https://youtu.be/1i86n12J5l4
Hard to argue with that, crappy, looks like you need front wheel bearings, rock your tire like that and look for movement between the hub and the cv that goes to the axle. Lenny used to sell a fix for your play, but I think he quit making them, an alternative would by to put some shim stock between the top plate and the slider piece, maybe replace the top plate with a thicker plate or make it out of steel.
Score!! $140 - http://www.protodie.com/Steering-Rack-End-Load_p_72.html
I'm pretty sure that one is the same one made by Latest Rage (http://www.latestrage.net/index.php?page=shop.browse&category_id=944&option=com_virtuemart&Itemid=1〈=en) which should be a direct bolt on replacement. The only thing I'm worried about are the splines. I read the Joyner version has 32 teeth and this one has 36 teeth?? I need to take it apart and count I guess.
  • 3 years later...
    • By Richard shepard
      I have a 2021 colman 400utv engine will start and idle, as soon as you hit throttle to move engine dies and will only start when you throttle it, let off throttle it dies, I replaced the injector and plug still the same, anyone have any other ideas
    • By Robert B
      Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
    • By azdesertdog
      A desert camp trip we took at Christmas in the desert
    • By William Carberry
      I have a MSU 500. I will start and run but requires basically full throttle to move. Does this machine have a drive belt? If so how difficult to change?
    • By mcraigchr
      I realize that many of you do not have diesel machines.  For those that do, this is for you:
      Just wanted to post my experience this past week.  Here in Texas, we had pretty good dip in temps.  For 4 days it did not get above 25.  At night, it was single digits or close to it.  I always put Sta-Bil fuel stabilizer in the storage tank (30 gallon).  And up until this tank I was using Power Service (white bottle) for anti-gel.  Never had an issue.
      This tank, however, I switched to Stabil All season (anti gel).  It is supposed to good down to -40.  Zap.  That is a big fat lie.  I put in twice the amount called for in the instructions.  Result was less than optimal.  I drove the SxS 100 feet (to go get the mail) and it died.  I looked at the fuel bowl and it was a cloudy, wax substance.  So, the Stabil did not work.  That said, I'm not sure that I ever tested the Power Service in the same manner.  So I am not saying that one is better than the other.
      What are your experiences?  Are these products inferior?  What do you folks in the northern states / Canada use?  Am I missing something?
      CC
