Joyner trooper seat replacement
By REDfletching
By moonrover
Mine is overheated/burned/melt at connection with its wire connector, parts are ordered to replace both them. This seems to be a common issue, and some of you already replaced it. I right now just connect the wires, so the fan runs all the time whenever the initiation is on, but it's better let fan runs as needed with a working temperature sensor/switch.
Question: Does some coolant come out by removing the switch/sensor from radiator? Or, is the threaded hole all the way inside radiator? If the answer is yes, I want to drain or extract some coolant to make its level below the sensor before replacing it, so I don't make a mess with coolant spilled out
Thank you.
By CYJSP2009
Dear Friends,
2022 Brand new Joyner CV Axles and CV Joint rebuild kits are comming
1. S650.03.02.02.00 ---Joyner 650 Commando Rear
7. 14274 --- 650 ider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
8. 15803 --- 650 Sand Spider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
Price: CV Axle: USD250/ Piece; CV Joint kit (without grease): USD110 send to door.
Buy 1 piece: Get 5% discount,
Please kindly note Qty for each part is not big and it is hard to forcast when there will be next offer for these kind of products unless there is sufficient confirmed order qty for productioin arrangement.
Payment method: Payoneer payment link ( can pay through bank account or credit card) or Paypal ( [email protected]) . Payment commission paid by the buyer.
Interested parties, please contact [email protected].
Good Luck
Casey / Leaf Asia
July-07-2022
By MJG
Hello,
I found an 08 Renegade for sale and looking to purchase it. I haven’t heard too much about these machines and any insight would be much appreciated. Are they good machines?
By lonerider98
At the end of last year my Coleman UT 500 will not go into reverse. I can hold it over toward the reverse to move it nut it won't lock into reverse. Anyone have this problem? Winter is just about over and going to have to get this resolved. Thank You!
