1997 kawasaki mule 550 - Battery problem
Hey,i had a dead battery in my 550, but when i took it off i forgot to look at where the wires came off. I remember the positive and negative wires, but there is one wire that i don't know where it goes. This wire looks like it is connected to a bolt or nut not far from where the battery is located. when i hook up the new battery, i cannot get any power. the only way to get power is when i connect this wire with the negative wire and then hook it to the battery, but when i do this, the break line ends up smoking. does any one know where this wire should go. Would it be some sort of grounding wire.
Thanks.
Link to comment
Share on other sites
  • 4 months later...
  • 1 year later...
    • By Todde67
      Replaced a broken of brake line on my’22 tboss 550. Won’t pump up, no pressure.
    • By amiracle40995
    • By Tejun
      Howdy Everyone,
      New member looking forward to learning and sharing more about UTVs. I have a 2019 Coleman Outfitter with the Hisun 550 engine. Does anyone know what Code Scanner will work with it ?
    • By CBS
      View File 2018 HISUN HS-550 Sector Rural King Manuals
      This is the Service manual, Parts manual, Owners manual, plus much more for my 2018 HS-550 RK UTV Side-by-Side.
      Submitter CBS Submitted 03/02/2024 Category Hisun
