2007 kawasaki mule 610 4x4
dony
I drove the mule one day and drove fine, I parked it and went to start it the next day, it would start and run fine for about 5 seconds and then die, I did see the fuel pump was flooding , I ordered a new one ,does any body know if this will fix the problem also I need pic of where the lines go from fuel pump , forgot to take a pic when I took it off its a Kawasaki mule 2007 610 4x4
thanks for any help
    • By malenurse13
      We just bought a used 2017 American Landmaster TW450. No hour meter that I can find, so not sure exactly how much it has been used.
      The first 2 days we had it, the starter was a little sketchy, but it started after 2-3 tries. Sometimes when turning the key, we would hear a loud metal "clink" sound. Like the starter made contact, but didn't have enough power to turn.
      THIS MORNING... Turning the key, we hear a single click sound. That's it. Even with a new battery, the starter is still doing the same thing. Both batteries (old and new) were reading 12.8 volts on volt meter. So I'm wondering what else could be going on? Any ideas on what to look for would be greatly appreciated...
      Thank you!
    • By buckrub
    • By joeam
      I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
    • By Nathon S.
      I have a Bennche 700 EFI Bighorn. I’ve recently been unable to get it to start. After a little troubleshooting I realized my fuel pump was not pumping fuel. This weekend I emptied the gas and replaced it with new. I replaced the fuel pump, fuel filter and fuel injector. I also replaced the battery, spark plug and made sure all my fuses and relays were good. I have confirmed that the float on the fuel pump is not obstructed. The UTV is about 12 years old and has less than 100 hours on it. It has not run in over a year.  Not sure whats going on?!? After doing a little reading I'm leaning towards it being an issue with the ECU or perhaps a faulty wire in the wiring harness. Anyone have any ideas on where to start looking or what I could be dealing with? Any help is appreciated, thanks in advance!
    • By REDfletching
