2009 Polaris ranger XP 700 EFI problem
garnell
My ranger runs fine until it warms up , then it intermittently stalls and misses , i slow down and some times it clears up in a few seconds and sometimes it takes a minute or too to clear up . Has anyone had this problem ? I thought it was water in the gas , so i put some heat in it and ran the gas tank empty , That didn't help .
  • 3 months later...
    • By johnpeter
      2016 Polaris Ranger 570 4WD On Ebay
      https://www.ebay.com/itm/166657642388?
    • By SwampTrapper
      This is my first buggy. I rode a Arctic Cat 500 manual for 19 years. My question is: with the engine running in Park and you rev the engine is the drive belt engaged and turning 🤷
    • By JFC
      I have a  3500LB Winch that only runs in one direction.  Inward but not Out.  Replaced the solenoid module.  Makes "click" when I push the "Out" button and the motor tries to spool out but then stops and begins to "click".   Does anyone have suggestions what I should try next?
    • By johnpeter
      2022 polaris ranger xp 1000 northstar ultimate On Ebay
      https://www.ebay.com/itm/226007623741?
    • By skittle021
      So I've got a Hisun 550 that I was doing some work on that required removing the CVT and it's housing. Upon attempting to reinstall the clutch, sheaves, etc, I found that the belt no longer fits - it's far too wide. None of the parts have been replaced, they're all OEM. Exactly the same parts as what I took off a few weeks ago.
      To be more specific, my belt is 1.25in wide, but the gap between the clutch and the primary sheave is only 7/8in wide. I'll include a few photos to explain.
      Has anyone ever experienced such a bizarre problem? Any help at all would be appreciated, I've been stuck on this for a month. I'm open to just about any suggestion.
      Photos:
