U joints
charlie
  • 2 months later...
    • By Timpiker
      My UTV is a few years old and gets very little use.  I just noticed the drive belt slapping the plastic guard and making some noise.  The manual tells me how to replace it but not how to tighten it.  Apparently, there is no adjustment.  Does anyone know if there is an adjustment?  Is the belt supposed to have a lot of slop in it?
    • By goindeep
      Well now i could use a lil help... i have a trooper in my shop now that has wiring issues... this poor guy paid another shop $1000 to re wire the body control harness, and boy oh boy did they chop it up!!! I am Buillding a new harness from scratch... what i need is a diagram that tells me what each fuse and relay control on the Engine fuse/relay block.. any help is greatly appreciated!!
      Josh
      No Limitz
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By Copperline
      I have a Coleman 550 (hisun). Wouldnt start and was sucking instead of blowing through the spark plug hole. Got to the timing chain and it was very loose and for sure the timing was way off. Got the tensioner off and set it to TDC and got the cam gear back aligned. Put the chain back on and set the tensioner as instructed and the chain is still very loose. I extended the tensioner as far as it would go to test and the chain is still loose.
      Any ideas what could be broken or wrong? Why would the chain be so loose?
    • By lowgear52
      Does anyone out there have a rear differential for a trooper for sale?
