2009 Mule trans 4x4
Glock_King
I bought a used 4010 and have had it a couple months now with no issues or problems. Recently I have used it to pull a stalled vehicle about 30 feet and pull out a stuck vehicle. Both times I put it in 4wd and locked differentials. After each occasion while driving the unit it feels as though the park brake is engaged and is very sluggish and loss of power. I have double checked the diff and 4wd as well as engage and disengage the brake in case it was dragging or slightly engaged, everything seems dime there. Any ideas why it would do this or what is causing it ? Any help would be greatly appreciated
  • 2 months later...
    • By AlphaSerenity
      Hello,
    • By Hugh
      Hugh
    • By johnpeter
      2016 Polaris Ranger 570 4WD On Ebay
      https://www.ebay.com/itm/166657642388?
    • By Bryan g
      We see a lot of the UT400 with shift problems, not going into gear, popping out of gear, grinding etc. There  is a bulletin Im sure everyone has saw about adjusting shift cable.  That dont always fix it.  I went round n round with coleman  on couple units. We are a Coleman warranty repair center"AFS Small Engine Repair "   I told them shift lever does not have enough travel .  No amount of cable adjustment  will increase travel . I  extended lever with piece on flat  iron by 3/4 of inch .  This gave shifter enough travel to properly engage into gear completely .  Last couple units to come in for this Coleman sent me a modified shift lever, with longer travel . Problem solved! Also , heads up if you get any new unit ,,,go over and check it out,  grease  all zerks, check air filter for being in backwards, check wiring harnesses for rubbing on rotating parts,  brake hose  routing , make sure not touching exhaust .  These are just  few of the more common failures I see .
    • By Irons
      Hopefully this helps somebody because I couldn't find any info on this runaway condition.
      Drove 1/2 mile to the gas station and when I started up to leave the starter stuck on. Turn key off starter is still running~! Limp it home wondering what the heck to do, get it in the garage and pull the negative battery terminal to get it to stop. Whew, WTF?
      Calm down and start checking things, starter is hot of course but nothing is smoking and nothing smells burnt. Pull battery cover off and start checking wires from battery to relay and relay to the starter. OK good nothing is hot, nothing is crispy and nothing is melted. Probably smoked the starter though. If this had happened to my wife and I wasn't around the machine would have run until the battery died and probably melted down/burned.
      I'll get to the point to save you folks some time and trouble. Because this is a kymco machine you need 2 different Kawasaki parts to make this repair, and information is scarce to say the least. The switch and a sub harness to connect it to the machine's plug.
      Everything works now, but the starter sounds horrible so I'll be changing that too before spring.
      Good luck out there and hopefully this is just a freak occurrence, but if I were you I'd get rid of this kymco part and put the Kawasaki replacement in now.
      Switch, Magnetic is part number 27010-0767
      Sub Harness Start Relay is part number 26031-Y034
