Clicking when trying to start
By Paul409
Have a Hisun 750 only 700hrs 21 model. Never had issues went to start it and there's a clicking sound under the seat I'm assuming it's the started relay. I for the life of me cannot find the starter, is there a way to test the relay.
Thank for any support
By didgeridoo
By bikermike
Since it is a royal pain to close the front hood, I went to add a charger wire so I don't have to worry about the hood, I found the screw on the positive post rusted . this utv is 11 months old. and since it's a Philips head, it was impossible to loosen . had to use vise grips.
replaced the screw with an hex bolt
By mcraigchr
I realize that many of you do not have diesel machines. For those that do, this is for you:
Just wanted to post my experience this past week. Here in Texas, we had pretty good dip in temps. For 4 days it did not get above 25. At night, it was single digits or close to it. I always put Sta-Bil fuel stabilizer in the storage tank (30 gallon). And up until this tank I was using Power Service (white bottle) for anti-gel. Never had an issue.
This tank, however, I switched to Stabil All season (anti gel). It is supposed to good down to -40. Zap. That is a big fat lie. I put in twice the amount called for in the instructions. Result was less than optimal. I drove the SxS 100 feet (to go get the mail) and it died. I looked at the fuel bowl and it was a cloudy, wax substance. So, the Stabil did not work. That said, I'm not sure that I ever tested the Power Service in the same manner. So I am not saying that one is better than the other.
What are your experiences? Are these products inferior? What do you folks in the northern states / Canada use? Am I missing something?
CC
By res2fr
I have an issue and I'm hoping that someone can help with a little Wisdom. I have a 2016 Massimo MSU500 UTV that blew a time chain while out riding. It has been torn down to replave the chain and Sprocket amount other things that will be renewed. The problem comes in with setting Top Dead Center on the motor. The Manuals all teel one to line up hash marks on the flywheel with a point on the side cover under what's referred to in several place as a manhole cover. Its a large headed cap/bolt that unscrews and allows you to view the edge of the flywheel. There are hash marks on the flywheel that your supposed to turn the crank until you get the proper alignment between a certain hash mark and a reference point on the Case. Problem is there is NO reference point on the case there. I also have another 2016 MSU500 and a 2014 Coleman 500. Not one of these machines have a reference mark of any kind in that location. (I have pictures if needed)
I know I can use the old pull the valve covers and rotate the crank and rely on getting the right point where Both Intake and Exhaust valves are closed at hopefully the correct point in the piston stroke. Is there any other reference point that could be used for this or is this the only thing left to use for finding TDC? Gotta Love documentation that doesn't match the equipment it's supposed to be for, any help would be greatly appreciated. Even if just to tell me that's about my only option.
Thanks to all who even take the time to read my rambling question.
Robert
