Oil filter and Oil change ?
    • By trevor
      my hisun 400 has ben leaking oil out of a small metal tube on the bottom near the oil filter. Got the side by side given to me after been sitting for a couple years  but 2 quarts in nothing happened my buddy went and worked on it and put another quart in it. i thought it just pushed out what it didn't need. but its dry as a bone inside. does have a good clatter coming from the top end as well, with oil in it. looking for some help not much on the internet about these things.
    • By Irons
      Hopefully this helps somebody because I couldn't find any info on this runaway condition.
      Drove 1/2 mile to the gas station and when I started up to leave the starter stuck on. Turn key off starter is still running~! Limp it home wondering what the heck to do, get it in the garage and pull the negative battery terminal to get it to stop. Whew, WTF?
      Calm down and start checking things, starter is hot of course but nothing is smoking and nothing smells burnt. Pull battery cover off and start checking wires from battery to relay and relay to the starter. OK good nothing is hot, nothing is crispy and nothing is melted. Probably smoked the starter though. If this had happened to my wife and I wasn't around the machine would have run until the battery died and probably melted down/burned.
      I'll get to the point to save you folks some time and trouble. Because this is a kymco machine you need 2 different Kawasaki parts to make this repair, and information is scarce to say the least. The switch and a sub harness to connect it to the machine's plug.
      Everything works now, but the starter sounds horrible so I'll be changing that too before spring.
      Good luck out there and hopefully this is just a freak occurrence, but if I were you I'd get rid of this kymco part and put the Kawasaki replacement in now.
      Switch, Magnetic is part number 27010-0767
      Sub Harness Start Relay is part number 26031-Y034
    • By Wesley
      I have a 2022 500 Hisun product, I have had them in the past. I change my oil myself and trying to drain through the hole where I remove the plug is a mess.  How does everyone keep the belly pan clean during the oil and filter service?
      Wes Jackson
    • By bfairchild21
      Please help I have a Massimo 400 buck that has an oil leak. The oil is leaking on the front side of the motor. It leaks out of a u-shaped steel pipe that has two banjo style fittings on it. I have tried using RTV and different banjo washers and have had no luck. It drips about one drip per second while it's running. I can't find parts for it at this time.
    • By catalyst
      We own a 2020 Kubota RTV-XG-850, with only 400 hours on it and it has been at the dealer 3+ months. We were just informed our engine failed and requires a complete rebuild at only 400 hours! There is a loss of compression in cylinder #1, which is causing backfiring and a loss of power. There is also excess gas in the engine oil.
      We are just outside of the manufacture's warranty period, and they are serving us a nearly $5000 repair bill, with only a 90 day warranty.
      A member at a different forum had the same issue at 22 hours and fortunately, his RTV is under warranty. He was informed that "short tripping" (as Kubota describes it) causes gasoline to enter into the engine oil, which causes a dilution of engine oil and eventually leads to catastrophic engine failure. This killed our engine in under 400 hours!
      Is anyone else with a 2018-2022 XG-850 running into similar issues?
