EJK Kit - Adjustments and Reviews
By Bassarino51
My 2014 Odes with less than 1000 miles suddenly won’t turn over with a fully charged battery.
By didgeridoo
By Rizzguy
Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
After one ride, the rear bolts have disappeared, because how much tension there is on the flex
And the bolts does not line up at the flange
Have a video before and after. And they are telling me that it’s my fault because it does not fit
wtf.!
What kind of idiotic people are even answering the phones these days.?
This guy has probably only read a book and never even driven a motorcycle in his life
Don’t waste your time with this bullshit products
By jim fisher
i just purchased a 2024 g2 z force 800 and would like to power some accessories with out hardwiring would a 3 way cig lighter adapter work plugged into the 12 volt outlet on the machine each splitter plug has on/off switch accessories include led light bar, micro midland 2 way radio and maybe a bluetooth soundbar obviously wouldnt be running these at same time.
By catalyst
We own a 2020 Kubota RTV-XG-850, with only 400 hours on it and it has been at the dealer 3+ months. We were just informed our engine failed and requires a complete rebuild at only 400 hours! There is a loss of compression in cylinder #1, which is causing backfiring and a loss of power. There is also excess gas in the engine oil.
We are just outside of the manufacture's warranty period, and they are serving us a nearly $5000 repair bill, with only a 90 day warranty.
A member at a different forum had the same issue at 22 hours and fortunately, his RTV is under warranty. He was informed that "short tripping" (as Kubota describes it) causes gasoline to enter into the engine oil, which causes a dilution of engine oil and eventually leads to catastrophic engine failure. This killed our engine in under 400 hours!
Is anyone else with a 2018-2022 XG-850 running into similar issues?
