Trooper ,Renegade, Commando 4 x 4 Actuator
silverbullet
New Trooper Steering Rack.Up graded in the USA.We disassemble the rack than we remove the gears and file the teeth and this will make it last longer.Plastic insert was installed buy the factory.We use a special grease that we found for C/V joints.It keeps the C/V joints 20 degrees cooler running in the dunes all day.
    • By aefron88
      I've seen a number of requests for the location of all the grease points on these machines, and there is no definitive list in the manual. This covers the UT400, but other Coleman/Hisun models should be similar.
      Tools:
      First to grease your machine you need a grease gun and some NLGI#2 grease. You will find it helpful to buy a needle attachment as pictured here, due to poor clearance on some of the U-joints. The rest of the zerks use the standard attachment.
      Technique:
      Wipe any dirt/grease off the zerk before greasing to prevent pushing gunk inside and causing excess wear.
      Push the grease gun on the zerk at a straight angle and give it a few pumps. You will hear an oozing noise or sea grease coming out from the outside of the greased area when you've put enough grease in, a few pumps should be plenty.
      If it's just oozing around the zerk you either don't have a good seat with the gun, or the zerk may be rusted and the check ball frozen. Try seating it again and regrease.
      Wipe up any excess grease when youre done to prevent making a mess.
      Greasepoints:
      Rear A-Arms are greasable with the wheels on from the rear, I took the picture with the wheel off for easier visibility
      That's it. All other Hisuns should be substantially similar.
    • By ETHIEL
      Spark plug keeps fouling. after 10-15 minutes of running any ideas what to look fore
    • By nods
      Less than 40 miles can barely start. Dealer is working with Hisun on a number of other issues on this UTV. Can not get clear info on the meaning of these E codes this is getting. Anybody have some clear info for me?
    • By AlphaSerenity
      Hello,
    • By lbnelms
      Grease fitting locations axis  500
