Joyner Rear Defferential
silverbullet
  • 4 weeks later...
    • By Abermp
      I have a DesertCross 800 that doesn't want to stay in low, it pops out when I let off the gas. No problem with the other gears. What do I need to do?  Thanks.
    • By Gary Odom
      I bought a tracker 88sx crew in 2023. It has a whishing noise coming from the front end. Starts out low and gets louder as speed increases. Took it back to the dealer and they said it was normal on this model. Any suggestions as to what may be causing this.
    • By Moos
      I replaced the fuel pump, ended up with a couple bad ones. This last one now worked fine for about 150 miles, now only works when its cool outside. (30-40). As soon as we hit 55 degrees, It will not run. Barely starts, runs rough, will not move. Any ideas? Another bad pump? Something else going on? Any help would be appreciated. Thanks.
    • By johnpeter
      2012 polaris rzr 800 On Ebay
      https://www.ebay.com/itm/196255632017?
    • By nods
      Less than 40 miles can barely start. Dealer is working with Hisun on a number of other issues on this UTV. Can not get clear info on the meaning of these E codes this is getting. Anybody have some clear info for me?
