Brake Pads & Clutch
By Kingfish
I've had a battery failure and need one replacement. The local distributor told me it might take up to four weeks to get one. I'd like to order one in sooner than that if possible. Any help would be appreciated.
By Hisun .500
So my hisun 500 is tore up and all the wiring is wasted i was wondering can i pull out all the wiring and just put in the. Basics .please help
By T-boss 410
Has anyone here replaced the 3 position ignition switch with an aftermarket 3 position switch? If so, which switch did you use, and how did you wire it up?
Thanks 👍
By Matt JB
Anyone replace the battery with a lithium? Is there an issue with the alternator and charging given the lithium has to charge at a higher voltage?
