WTB trooper rear shock
ERV JR
If anyone has a stock rear shock that is good please let me know what you want for it. I blew one out on saturday and have a few more trips left this season and just cant swing the expense of aftermarket shocks at the time
I have a complete set of shocks available as I've upgraded to Kings last year. I have no idea what they're worth but I'm willing to trade them off. What I need is one of those new lever controlled 4 wheel drive lockers.
Link to comment
Share on other sites
Did you get the kit from No Limits?
No he did not, I just got my 5 kits in last wed.. I have not sold any at the moment but hey when someone needs I got em.. sorry to hijack the thread.. but I also have that shock you need 817-695-1151 m-f 9-6 and sat 9-5
Link to comment
how much where they ? I heard from a friend that used to use them at his shop that they charge alot to ship and that in the end the kings arent much more .whats the price with coils
Looks like I paid $685 for shocks and springs 8/09, I did have to use limit straps, but they don't top or bottom out any more.
Link to comment
thats not too bad, where they they 12 inch 2.0's ? also what spring rates did you decide on? did you corner weight the trooper or just guess. howa the ride quality? much better ?
Link to comment
The is where I will be purchasing my Fox Shocks. Off Road Warehouse - Very knowledgeable! I think the shock guy is Brian at the San Diego Store. Not home at the moment so I am going from memory but these are the shocks I am replacing with. Off Road Warehouse - Shocks Fox Shocks 2.0 Fox Coil-Over Emulsion Shocks Fox Shocks 2.0&quot X 10.0&quot Emulsion Coil-Over # 980-99-004-A
rocmoc n AZ/Mexico
Link to comment
rocmoc n AZ/Mexico
that link shows a10 inch shock, is thta what you used I was thinking a 12 and straping it.. why not a resvior shock there is room ?
Link to comment
Guest Lenny
10 inch shock is plenty. Flatbed used 8" and he knows more about suspension then any of us as that is what he did for years for the competitive track and offroad vehicles.
Link to comment
Lenny is correct. The 10" is more than enough as the shock lays at an angle and the the swing arm travels the greater distance of 13+ inches. Stock is the 8" that Flatbed used but I relocated the mount on the swing arm for a better weight distribution to the swing arm and increased the travel distance of the shock thus the 10" shock. 12" would be too much as you will be out the sweet spot of the shock valving.
rocmoc n Mexico/AZ
Link to comment
How do you like the King shocks so far? Did you have to do any modifications to make them fit?
Link to comment
The King shocks are great. I didn't have to do any modifications at all - just simply bolted them in. Depending on the riding I'm going to do, I adjust the nitrogen pressure before I head out. For example, if I'll be riding on hardpack I increase the pressure so I don't get as much roll cornering. For the rougher, cross country stuff, I lighten it up a bit. So far, I can honestly say it was well worth all the money ... and they were expensive!
I've had my T2 about 6 feet in the air .. unintentionally .. and it landed solidly, absorbing the impact and maintained control. The guys I was riding with were totally impressed.
Link to comment
Barry thanks for the info, what preasures are you adjusting too?
Greg
Link to comment
Greg
When running on hardpack the fronts are at 200 # psi and the rears 265. Going cross country I drop the fronts to 175 and the rear to 240. This seems to work pretty good. Next I'm going to start experimenting with the spring preloads as soon as I figure out how to measure the set-up.
Link to comment
    • By lowgear52
      Does anyone out there have a rear differential for a trooper for sale?
    • By Kingfish
      I've had a battery failure and need one replacement.  The local distributor told me it might take up to four weeks to get one.  I'd like to order one in sooner than that if possible.  Any help would be appreciated.
    • By AndySwish33
      Brand new t boss 550. couple of questions.
      1.  Do you need speakers in order to play music ?  Hooked my phone to Bluetooth no sound
      2.  On screen registration.. it won’t let me fill in the info on the touch screen.  Navigation works but the registration portion does not
      3.  Is there a data plan you can get or need ?
      thanks everyone
    • By CarlB
      I have a 2022 Hisun 750 Sector which comes with a locked rear differential. Was wondering if it would be possible to install an unlocking differential.  I see that there are some Hisun made machines that come with the unlocking rear diff, such as Cub Cadet Challenger, some of the Massimos, and probably others. My concern is whether these would be a direct bolt on, using the original axles, drive shaft, and of course matching gear ratio. I've tried to match up part numbers but it seems every brand has their own number system even for parts that I know are identical. If anyone has ever done this swap or has any information about the whether these unlocking rear diffs are comparable to the Sector, I'd appreciate your input.
    • By mehe
