New Trooper Power Steering unit
plumber
I paid around 250.00 for the unit with shipping.....It is the Corsa C model 00-06 like 70.00 for the controller...The BIG hard part of it is trusting the seller to ship!...I had the first one took me a month and a half to get....I was going to buy 5 steering units and controllers and sell them as kits here in the states but being the economy is not good I'm not sure if I should do so...I have 1 more in my possession. I need to get the controller ordered.... I am like the rest of America I would like to make some money on them....LOL There defiantly not a drop in.. The computer box is not sealed.. So silicon and placement I think is critical....It was all inside the car so its not a sealed unit computer wise...I am thinking I would sell for around 400.00...Any thoughts? I prob could make this into a bolt in application but I was hurting on time..SO I slammed it in with a welder lol........IDEAS Welcome.......
Controller ----- http://www.ebay.com/...=item2a227b6750
Steering ----- http://www.ebay.com/...984.m1438.l2649
Watch when you are looking at them the prices are in there currency........A lot wont ship to us so be careful if you buy one without contacting them....!
P.S. Don't for get they come in tilt columns or No tilt....Mine is tilt...
Link to comment
Share on other sites
  • Replies 294
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
My opinion is NO, the limiting factor is the CV joint, if you jack the front end via the lower pivot point and disconnect either tie rod and turn the wheel and rotate it, you will feel the CV joint starting to bind. The other possibility though is to put a pivoting system on the rear end, have fun and let us know how it works.
Link to comment
Yes you can make it steer sharper. MIne steerrs real sharp now. I can do a 180 degree turn and when I measure from the inside wheel outter edge at 0 degrees then at 180 degrees, it's 16 feet across. In other words if you put 2 eight foot sheets of plywood end to end, I can scrape the end on one end and then at 180 degrees be scraping the end on the other end. Yes it is in the rack and pinion. It needs a little more travel. The CV joints can take it ok but you have to watch the tie rod end joints. I had to heat up the arm that the tie ron connects to on the spindle housing and twist it a bit so it wouldn't bind when turning tight. I'm no longer struggling with hair pin turns. It's nice.
Link to comment
How did you get more travel? Stock steering box or aftermarket?
I believe stock and if I remember correctly, he loosened the jam nut at the forks on ends of rack. He loosen the jam nut then adjusted it from there.
I had heard our stock cv take a lot of angle but the super gorilla or whatever brand I can't remember lol brag being able to have angle of 45 degrees...don't quote me on that though...
Sent from my XT912 using Tapatalk 2
Link to comment
I'm using a steering rack and pinion out of a smart car. It has a longer travel. I always thought that maybe the stock rack could have a couple of extra teeth cut into it. Then again would have to check if it would seal with the boot on the ends. Kinarfi has my steering rack. Maybe he would send it back to me and i'll try check it out to see if it can be done. YOu can't get it by loosening the jam nuts, you need more rack travel like about 3/4" if I remember correctly.
Link to comment
Ok Dan if ur gonna start making and selling power steering for 400$ I'd be interested providing I don't have to do a lot of welding! Lenny if you need more travel couldn't we just as length to the tie tod arm I'm sure it wouldn't need to be much on both sides and then adjust ????
Yeah for $400 ill buy too
Link to comment
Lengthing the tie rods won't do in. You need need to move the wheels farther in both directions and the only thing that can do that is to have the rack in the steering box travel farther in each direction. Stock, you are limited by the number of teeth on the rack. You simply get to the end of the teeth. Adding a couple of teeth may give you the extra travel needed if the box boots will still work. Machining the teeth in wouldn't be too hard for a tryout.
Link to comment
Yeah I might try the teeth adding part...And I have to check into making it a bolt in...
Link to comment
I'm using a steering rack and pinion out of a smart car. It has a longer travel. I always thought that maybe the stock rack could have a couple of extra teeth cut into it. Then again would have to check if it would seal with the boot on the ends. Kinarfi has my steering rack. Maybe he would send it back to me and i'll try check it out to see if it can be done. You can't get it by loosening the jam nuts, you need more rack travel like about 3/4" if I remember correctly.
If I remember correctly, the teeth on the rack don't have an end stop, you just run out of teeth. There is actually a tooth cut into the threaded part at the ends and it's the jam nut that stops you. I can send the rack back to you or if a photo will do, I'll try to remember to bring it with me the next time we hook up for a ride. Actually, I've been thinking of borrowing rest of the steering box from you so I can rebuild the old power steering unit with oil bathed gear geared down mount instead of the chain we had.
Link to comment
photos of the steering rack
If you want less turn radius, you can run the stop nuts out some more, and maybe get some more by moving the lock nut to the inside. The yokes could be screwed out out a little further and the tie rods shortened to make for it so the wheels don't get a change of toe in. You may have to grind the outer edges of the lock nut off so it slides inside the steering box, that should take up all the play available in the CV Joints. Also remember that the pinion only the center of the rack, so you don't need to cut any more teeth, it's the stop nuts that are protecting the CV joints from getting into a bind.
photo removed, needed the space elsewhere, Kinarfi
Link to comment
I was thinking that there was some smooth rack shaft after the teeth. The picture shows teeth its entire length. If this is the case then the rack would need to be replaced with a longer one. Something doesn't seem rignt though because I don't remember the teeth sticking past the dirt boot. The boot wouldn't do much good if it has to seal where the teeth are.
Link to comment
Yeah, I think your right. Probably the easiest thing to do then would be to weld on a little extra length to the rack and cut some extra teeth or just go to a longer rack.
Link to comment
I feel that this steering unit can be made into a bolt in but, And I say But you are driving cost up. If you have a welder friend it is pretty easily done. you have to remove the old steering bracket that is welded to your frame. gets in way and angle is all off...The way I did it is to weld your old steering shaft from the rack to the new one basically connect your shaft with there universal joint. You have to cut your steering column shaft about at 1inch out . If you would ever want to use it for something else...(If I had to do it again I would have cut it off flush )and cut off right at splines of electric unit and insert your old steering shaft into the power unit and weld it unless you have a better way. Also I took the steering computer apart for little metal tabs ( EASY ) and silicon-ed the perimeter (Light layer) These units were designed to be inside. I also did some on the connections to help seal them. I also used Dielectric greased the plugs real well. You will find the computer that is mounted to the steering column. I removed it and placed it right under the column and bolted it to bottom plastic dash. I ran a hot wire from the winch Hot up to it for power. The one wire on the control kit needs to be wired into your ignition so that it turns on and off with key..We do have an accessory spot on it so just use that wire....Other then that if you remove the Black plastic at the top of the power steering column it fits nice into original place...By the way it is a pain .It is molded around it....Uh don't cut through the hump on top it is part of the aluminum housing with plastic over it....I can get into more detail if needed but I think most on here could do it without any help from little ole me...LOL
P.S. I dont know if the tilt column is needed but is nice to have. But you need to reconfigure the lock for it...I havnt came up with a good one yet.
OH YEAH don't cut the bold hole off on the bottom side of the column that supports the tilt lock bar. Also you can pull it out and put it back in so no worries there....
HAPPY THANKSGIVING!
Link to comment
I is pretty straight forward. But mine is in so I know a little about it. Plus I will give you more details. I am waiting on the control for it now. I just ordered it Mon. If you have a good welder buddy ( Can weld pretty good cause your life is in his hands) it isn’t bad at all.2 people is key in the positioning. Need some 1/4 inch by I think 1 1/2 by 2 ft and cut weld and drill like 5 holes 5 bolts and 2 spacers.
To answer your question. The directions come with the controller.... I will post a video on here too of mine....If you work on it and don’t think constantly about how to do it a 8 hour day is way more then enough...Figuring out took me awhile.....If you do it the same way I did that will save you time. There always that...Well I could do it this way thing that jumps in...LOL...Need some wiring skills as well as soldering. Plus it is a perfect time to dielectric grease all the plugs to keep moisture out. Now when all said and done I am going to either build a box for storage up front...Or take a piece of rubber like someone did on here and close in the back dash covering the power steering motor...It looks like it is sealed pretty good but still want it closed in.. Happy Thanksgiving!
Link to comment
I can tell you guys one thing.....If I was to rate what was the BEST for me to upgrade...WOW power steering...Hands DOWN for me! Crap I can turn! feels like someone took the lead out of it. Hell! Now I can go down the road and steer it back and forth on the road and it actually sways and needs sway bars....LOL
Link to comment
    • By Steve Toney
      Hello, my name is Steve and just signing up.  Bought my first UTV yesterday.  It is a Massimo T-Boss 550.
    • By SafeSledBryan
      Hey guys! My name is Bryan and i am the owner and creator of Safe Sled. Not some crazy corporate backed recovery product, but just some guy with an idea.
      4 years ago, I suffered 11 strokes, and am now 50% paralyzed on the left side of my body. I am unable to work a normal job anymore. I was working on the sled 2 years before this all unraveled. My wife told me to keep working on it since i was pissing her off staying home and doing nothing.
      I still plan on improving and implementing different ideas as the product’s revenue continues to grow.
      if the sled is appealing to you, please check out my website, safesledoffroad.com
      Safe Sled Website
    • By CBS
      Greetings from Southern Illinois. My name is Bruce and I currently have a Hisun HS550 Performance Rural King. I have had nothing but problems with this unit replaced so many parts of it and of course, it stopped working and will not start again for about the 3rd or 4th time since 2018 it only has a little over 500 miles and has cost me a bunch of money and headache and the Rural King where I purchased it has a repair man who is certified to work on HISUN but he charged me a little over $600 to repair it once back a few years ago and when I got it home after it being in his shop for over 2 weeks the thing worked for a very short time but when I went to start it the next day it was the same thing and they wouldn't check it further without me paying for service, labor, and parts and I went around and around with them and since there aren't any dealer service centers for Hisun near me and even most of them can't get to it for weeks to months and it could be at their shops for months as they tell me they have problems getting the parts needed from Hisun to fix these giant paper weights. Oh, and you can't buy a scan tool (code reader) Delphi 190121 unless you are one of their dealers and I can't find any other scanner tool that works with it except the Tiny Scan Tool which I purchased and it will work if I could find the correct adaptor cable and connector to connect the Tiny Scan to the diagnostic port on the Hisun HS550 Performance Rural King. Yep, I pretty much have been screwed every which way that can happen with this machine. I am disabled, have cancer, and am on a fixed income so I need help if anyone knows what the connector is called (type or part name) that will plug into the diagnostic port to get my scanner to work it is a 6-pin connector and I hear it only has to have 3 wires connected to it.
    • By jim fisher
      i just purchased a 2024 g2 z force 800 and would like to power some accessories with out hardwiring would a 3 way cig lighter adapter work plugged into the 12 volt outlet on the machine each splitter plug has on/off switch accessories include led light bar, micro midland 2 way radio and maybe a bluetooth soundbar obviously wouldnt be running these at same time.
    • By catalyst
      We own a 2020 Kubota RTV-XG-850, with only 400 hours on it and it has been at the dealer 3+ months. We were just informed our engine failed and requires a complete rebuild at only 400 hours! There is a loss of compression in cylinder #1, which is causing backfiring and a loss of power. There is also excess gas in the engine oil.
      We are just outside of the manufacture's warranty period, and they are serving us a nearly $5000 repair bill, with only a 90 day warranty.
      A member at a different forum had the same issue at 22 hours and fortunately, his RTV is under warranty. He was informed that "short tripping" (as Kubota describes it) causes gasoline to enter into the engine oil, which causes a dilution of engine oil and eventually leads to catastrophic engine failure. This killed our engine in under 400 hours!
      Is anyone else with a 2018-2022 XG-850 running into similar issues?
