Hayg Fuel Pump
showa
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
well it would be safe to say that the gas tank was the problem! no skips,spitts or sputters! I would suggest that thi get put in as well when someone has fuel problems, thanks for the help and the info guys, you were all a tremendous help and a wealth of knowledge, my hats off to you all!
Thanks, Mike
Link to comment
Share on other sites
    • By moonrover
      Mine is overheated/burned/melt at connection with its wire connector, parts are ordered to replace both them.  This seems to be a common issue, and some of you already replaced it. I right now just connect the wires, so the fan runs  all the time whenever the initiation is on, but it's better let fan runs as needed with a working temperature sensor/switch.
      Question: Does some coolant come out by removing the switch/sensor from radiator?  Or, is the threaded hole all the way inside radiator?   If the answer is yes,  I want to drain or extract  some coolant to make its level below the sensor before replacing it, so I don't make a mess with coolant spilled out
      Thank you.
    • By nods
      Less than 40 miles can barely start. Dealer is working with Hisun on a number of other issues on this UTV. Can not get clear info on the meaning of these E codes this is getting. Anybody have some clear info for me?
    • By MJG
      Hello,
      I found an 08 Renegade for sale and looking to purchase it.  I haven’t heard too much about these machines and any insight would be much appreciated.  Are they good machines?
    • By shaught66
      Hi. I am looking to purchase a plow kit to fit my 2022 Axis 500. I have looked online but only found one place to get one.  Does anyone have any place I could look? Thank you for your help.
