My T-4 Status
By Hi sun 500
hello everyone, i just joined this forum to try my luck, few days ago i bought an old (dont know exactly), 2011/14 hi sun 500cc ""carburated"", was not running at the time, but i fell was a good deal and decided it to bring it home to play with it, this is the issue, i bought and installed a new carb, and pump, i repositioned the battery location and upgraded to a "car batt", reconnected the fuel lines and started it, but it only runs with the choke ON, i checked the bowl, it does have fuel,but for some reason wont inject it to run, i came across a video that say that ""the body small tank had to be connected for the cart to run" (was deleted when bought), sure enough i got it to run sporadically , but the so called ""small body tank'' often runs out of fuel and wont refill itself , i had to couple times do it manually, so how does that small tank works ?..what does it do?..and why if bypass it , the cart wont start?....any help?..thanks so much!!!
By moonrover
Mine is overheated/burned/melt at connection with its wire connector, parts are ordered to replace both them. This seems to be a common issue, and some of you already replaced it. I right now just connect the wires, so the fan runs all the time whenever the initiation is on, but it's better let fan runs as needed with a working temperature sensor/switch.
Question: Does some coolant come out by removing the switch/sensor from radiator? Or, is the threaded hole all the way inside radiator? If the answer is yes, I want to drain or extract some coolant to make its level below the sensor before replacing it, so I don't make a mess with coolant spilled out
Thank you.
By weasel
By Round
Bought a Massimo 500 last night. Stopped and filled it up on the way home and I put the wrong gas in it. Is there a drain plug on the bottom of the tank that I can get to or will I have to siphon it out?
By Coleman400
Hey all. I need to change my plug in my ut400 and I remember seeing people in here saying to get a certain one that was better than what it came with. What was it?
Also I need to do an oil change. Are the tractor supply oil change kits ok to use?
Any help here is appreciated!
