Power loss for 5 seconds at a time
All I have been reading but not finding what is happening to me yet. I have been fighting the same problem for months now.
The t-4 will flat out go at times then it will loose power down to 500 rpms or so for 5-15 seconds then you hear it regain the rpms and off I go again.
I have completely cleaned the gas tank, repositioned the filter changed the filter numerous times. Added the a higher pressure Bosch pump.
I thought it was a dirty tank with debris getting in the way since when I took my foot off the gas it would recover in a few seconds 5-15.
I read the post about the IAC but most of them were about over revs. I thought maybe it was the computer protecting itself, if too high of revs.
I'm too the point just just throw this engine out and put a VW in it.
Link to comment
Share on other sites
I just posted a thread about the engine malfunction signal, it may be worth your while to hook it up and see if it tells you that the engine has malfunctioned or not during these episodes http://www.utvboard.com/topic/1834-trooper-computer-outputs-we-can-use/page__view__findpost__p__14692 Let me know if you need help, as for the actual problem, no real ideas about it, can't be rev limiting can it?
Link to comment
Guest Lenny
Rev limiting kicks in when you reach as specifit rpm and then turns off when the engine gets to an rpm maybe 100-200 rpms lower. It's mmore of a bap, bap, bap, on and off and not a 5-15 second delay. I would run a fuel pressure gauge directly from the fuel rail input and put it where you can see it when this happens. it the fuel pressure stays ok then it's not a fuel problem. Could be something might be heating up and loosing connection. Could be in the computer.
Link to comment
I HATE problems like this.
This sounds like a computer or fuel injection problem.
Check:
Does this happen only when hot?
Does it sound like its being bogged down from excessive fuel, or is it being starved?
What's the fuel pressure read when this is happening? You might want to relocate your fuel pressure guage. (I've thought of it myself, cus it would look so darn cool to have it where I can ACTUALLY SEE IT)
Check your plugs immediately after the event. What is their color? I'd check both oxygen sensors. Perhaps one is sending the wrong signal intermitantly...are the O.S. cables ok?
Check your comp. Jeese, after reading a thread on water entering the ECM, you never know.
I'll probably dream up a few more useless questions tonight.
Link to comment
Thanks to all so far. I hope to get time this weekend to dig in with the mechanic
I will relocate fuel gauge if possible, I believe it is dropping but unsure because it sounds starved of gas. New Bosch pump put in a few months ago, could be an intermittent bad pump.
It is has happened both hot and cold, but moe when hot.
I will keep this thread updated until the problem is fixed or I put in VW motor.
I will also IAC valve and the computer for moisture.
Will also see if someone has the equipment to read the fault codes.
Link to comment
If the fuel pressure drops, the fix is pretty simple. Hope the fuel pressure drops. Check all your plugs too.
One more question. Does it sound like a cyl or two is getting cut out, or is it some weird knocKing sound, or is it just like you throttled down? If it's a comp or CPS sensor issue, your plugs will likely tell you.
Link to comment
Crank position sensor. If your CPS is bad or CPS wires are shorting, you'll have the ECM confused.
FYI, I'm speaking from motorcycle experience. I've just gotten my Joyner, so I have next to nothing on it. However, it does have electronic ignition, so it may suffer many or most of the same issues I've faced before.
Link to comment
Guest Lenny
If you need a CPS, you'll have to get one from Casey or Silverbullet. I managed to find one the would fit up, not easy to do, but the computer wouldn't read it. Had to get one from Silverbullet for it to work. It's not the IAC. I have my fuel gauge comming up in between the seats behind the parking brake handle. If something is acting funny, I can quickly glance at it and see if it's the fuel system or eliminate it as the problem. I find it really nice to be able to monitor it at will.
Link to comment
Not sure if you came across this topic http://www.utvboard.com/topic/1423-power-loss/page__hl__%2Bloss+%2Bof+%2Bpower__fromsearch__1 but it sounds like the problems you are having is very close to the same as what i was having. I checked everthing and like you pulled the tank a couple times as well as new fuel filter,air filter fuel lines regulator, checked all wire connections and finally replaced the computer and have not had the issue since.Too bad your not close to someone with a trooper to switch them out just to see if that is it.
Link to comment
Guest Lenny
I've recently was given a Trooper ECM to sell. Was getting ready to put it on Ebay. Asking $350.00. This came out of a running Trooper and to reconfirm it being good I tested it on Kinarfis Trooper when we were at Coral Pink Sand Dunes. The computer is good. I don't like to ship stuff back and forth like computers so if it doesn't solve your problem it will be up to you to resale it to get your money back out of it. Let me know if your interested and I won't put it on Ebay.
Link to comment
Lenny I will take it. Dumb question same computer for the T-4. I understand once I buy it's mine if I don't need it. I'll probably hold on to it or put it on eBay.
Link to comment
Link to comment
Guest Lenny
Lenny got the computer. Just back from 3 days at the Baja 500. Will try to get the computer changed soon but weather is getting hot already to spend too much time testing.
Good luck
Link to comment
    • By lonerider98
      At the end of last year my Coleman UT 500 will not go into reverse. I can hold it over toward the reverse to move it nut it won't lock into reverse. Anyone have this problem? Winter is just about over and going to have to get this resolved. Thank You!
    • By joeam
      I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
    • By ETHIEL
      Spark plug keeps fouling. after 10-15 minutes of running any ideas what to look fore
    • By Hi sun 500
      hello everyone, i just joined this forum to try my luck, few days ago i bought an old (dont know exactly), 2011/14 hi sun 500cc ""carburated"",  was not running at the time, but i fell was a good deal and decided it to bring it home to play with it, this is the issue, i bought and installed a new carb, and pump, i repositioned the battery location and upgraded to a "car batt", reconnected the fuel lines and started it, but it only runs with the choke ON, i checked the bowl, it does have fuel,but for some reason wont inject it to run, i came across a video that say that ""the body small tank had to be connected for the cart to run" (was deleted when bought), sure enough i got it to run sporadically , but the so called ""small body tank'' often runs out of fuel and wont refill itself , i had to couple times do it manually, so how does that small tank works ?..what does it do?..and why if  bypass it , the cart wont start?....any help?..thanks so much!!!
    • By skittle021
      So I've got a Hisun 550 that I was doing some work on that required removing the CVT and it's housing. Upon attempting to reinstall the clutch, sheaves, etc, I found that the belt no longer fits - it's far too wide. None of the parts have been replaced, they're all OEM. Exactly the same parts as what I took off a few weeks ago.
      To be more specific, my belt is 1.25in wide, but the gap between the clutch and the primary sheave is only 7/8in wide. I'll include a few photos to explain.
      Has anyone ever experienced such a bizarre problem? Any help at all would be appreciated, I've been stuck on this for a month. I'm open to just about any suggestion.
      Photos:
