Electric 4x4 locker failure question
By aefron88
View File Hisun HS400/Coleman UT400 Parts Diagrams
Compiled document with parts diagrams for Hisun HS400/Coleman UT400 for help in repairs where the service manual diagrams are poor or non existent.
Submitter aefron88 Submitted 04/15/2024 Category Hisun
By buckrub
Hey guys! Newbie here. I'm an old man who's better with plowing a mule (4-legged kind) than these newfangled beasts. I, and a friend of mine, just bought new Coleman sxs and are having to finish the assembly. I've been reading on this site and I'm falling on the mercy of you experts. The only way I'm an expert is that an "ex" is a has been, and a spurt is a drip under pressure. LOL First off, the 2 buggies have no ignition switches. They seem to mount on the dash, not the opening in the steering wheel shaft cover, so we ordered new ones that are supposed to fit. They are 8 inches long, and have a 4-wired white plugin which is slightly rectangled when looking at the end of the plug. The trouble is there's nothing to plug into. There is a three-wire grey plug close enough to reach the four-wire plug, but of course, they are not compatible.
Secondly, the blinker, light, ect. unit on steering wheel just spins around when touched. I see no way in heaven or earth to secure it. I've looked at a diagram on the Powersports site, but can't detect how it mounted. Fellows I'd be so grateful for any help with this. Me and my mule will even plow your garden for free, for your help. LOL
By Smittay
(posted a similar question to the Hisun folks) Looked at a lot of UTVs lately. Couple Questions about Massimo. Some people say they are just cheap with no customer service. Other people seem to have no problems with them.
Any opinions on Massimo durability?
Heard parts might hard to get. Is that true?
What models are the best?
If you had one and didn't like it what do you recommend?
By moonrover
Mine is overheated/burned/melt at connection with its wire connector, parts are ordered to replace both them. This seems to be a common issue, and some of you already replaced it. I right now just connect the wires, so the fan runs all the time whenever the initiation is on, but it's better let fan runs as needed with a working temperature sensor/switch.
Question: Does some coolant come out by removing the switch/sensor from radiator? Or, is the threaded hole all the way inside radiator? If the answer is yes, I want to drain or extract some coolant to make its level below the sensor before replacing it, so I don't make a mess with coolant spilled out
Thank you.
By LindaCall60
Purchased a 2011 bighorn banchee. Needs motor work. Not sure what. Husband is mechanic but not computer savvy. So, is there a manual that will tell him how to tear this down? We have down loaded a service manual, but he says it doesn't tell him what he is looking for.
