Installing Turbo
  • Replies 75
  • Created
  • Last Reply
Top Posters In This Topic
How is that intake working for ya so far???
the controller i got from dedub i kept for myself although i have a Trooper in the shop now for a turbo and intake kit and 3 more to follow so i am gonna need to order 4 more from you soon....
Josh
No Limitz
just let me know my manfoild working good
Link to comment
Share on other sites
I'm running stock injectors right now because I only have the standard EJK controller, no vacuum port. When I tried running the 19lb injectors it was too rich before boost kicked in. I'm hoping to get the controller with the vacuum port so I can get the 19lb injectors dialed in. The turbo will run fine on stock injectors and 6 lb boost. I'm trying to run 10lb boost, and I know there's more power there than what I can get because it goes lean (17~18 on the AFR gauge) at 10lbs with stock injectors, EJK max injection.
Dedub, how is the vacuum ported fuel controller working for you?
Link to comment
mine is working good with stock injectors i got all fuel i need an more.
Link to comment
So are you the one to talk to about getting the vacuum ported fuel controller? How much are those going for?
$300.00 the are programed to work with stock injectors. if you put bigger injectors in it will over fuel off bust. it will have to be reprogramed for the bigger injectors. just so everbody knowes up front. thank
Link to comment
    • By lonerider98
      At the end of last year my Coleman UT 500 will not go into reverse. I can hold it over toward the reverse to move it nut it won't lock into reverse. Anyone have this problem? Winter is just about over and going to have to get this resolved. Thank You!
    • By Hugh
      Hugh
    • By MJG
      Hello,
      I found an 08 Renegade for sale and looking to purchase it.  I haven’t heard too much about these machines and any insight would be much appreciated.  Are they good machines?
    • By Kalyla Jackson
      Hey all!
      I'm on a mission to buy my first UTV soundbar as a gift for my dad. I'm aiming for something that offers great sound quality without breaking the bank – my budget is around $250. Right now, I'm considering options like ecoxgear, kemimoto, and boss.
      Does anyone have experience with these brands or specific models that you'd recommend? Any advice or suggestions would be super appreciated!
      Thanks in advance for your help!
    • By aefron88
