Broken Output Shaft
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
By Copperline
I have a Coleman 550 (hisun). Wouldnt start and was sucking instead of blowing through the spark plug hole. Got to the timing chain and it was very loose and for sure the timing was way off. Got the tensioner off and set it to TDC and got the cam gear back aligned. Put the chain back on and set the tensioner as instructed and the chain is still very loose. I extended the tensioner as far as it would go to test and the chain is still loose.
Any ideas what could be broken or wrong? Why would the chain be so loose?
By fishhouse3
This machine is ready to go and needs nothing - just hop in and hit the trails! I have over $20k invested in this machine. Priced VERY fair to sell quick at less than half that!!!
By AndySwish33
Brand new t boss 550. couple of questions.
1. Do you need speakers in order to play music ? Hooked my phone to Bluetooth no sound
2. On screen registration.. it won’t let me fill in the info on the touch screen. Navigation works but the registration portion does not
3. Is there a data plan you can get or need ?
thanks everyone
By Dave P
Bought a used 4x4, engine runs. Tried rebuilding both pulleys. Ended up buying a transmission pulley system. The new one is aftermarket. The old one wallowed out and fell off.
The new one seems not to have enough splines inside. Seems like it is freewheeling. When it revs up and gets smaller pulley diameter, does it jump on the spline shaft? The driver pulley on the engine gets larger when it revs up. Had to make a pvc collar for the belt to sit on in the grove. No parts for sale on this pulley. Is the belt supposed to sit at the bottom? There must be a trick to get the belt on. Any ideas?
Thanks Dave in Florida
