  • Similar Forum Topics
    • 2012 Kawasaki Mule 4000 Hood release latch cable replaced
      I have a 2012 Kawasaki 4000 Mule and the hood release cable is frozen and will not move. I want to replace the cable and have removed the fenders, hood, cargo box to access the cable. I finally had to remove the plastic dash far enough away so I could get a wrench on the nut holding the cable release knob in place. That's a lot of fun. I cannot remove the pin holding the cable to the release bar mechanism. Is that a force fit pin or what. There are no keepers holding it in place. Any suggestions on how to get the cable out? I can see why the previous owner never fixed it as you have to remove the whole front to get to the cable. I've tried penetrating fluids to make the cable work with no success. Your help is appreciated. Gerry C.
      By Gerald Clarendon Sr, in Kawasaki UTV SxS Forum
      • 13 replies
      • 393 views
    • Cub Cadet Diesel UTV key on no lights and wont start
      New here!  I have a 2003 Cub Cadet Volunteer Diesel ran everyday 1 day fine nothing the next. anyone had this problem? when I turn on the key not even the lights will come on. I took the switch apart it seems fine put it back in. checked the 2 blowout fuses are also fine (even tried new ones), switched the 3 relays around they seem fine to hate to have to take it in an get wallet raped someone must have had this problem before any help would be greatly appreciated!
      By uponahill, in Cub Cadet UTV SxS Forum
      • 50 replies
      • 2,657 views
    • Lights for 2510 Mule
      Anyone know how I can upgrade the lights on my 99 2510 Mule ?
      By nybuckboy, in Kawasaki UTV SxS Forum
      • 21 replies
      • 677 views
    • Electrical Gremlins (Wench, Lights and 4x4)
      Hi all, I'm running into a strange problem with the chassis electrical on my Trooper.  I had someone push me off a rock pile I was high centered on and they smashed a few of my taillights.  I didn't think much of it at the time as taillights are easy to replace, but the next morning I couldn't turn on my headlights or spotlights, my wench motor wouldn't respond to the in/out switch, and the 4x4 switch won't take me out of 4 wheel. Looking at the Trooper wiring schematic, I can see that all these switches are on the same ING1 circuit so I'm concluding it is some type of electrical issue.  I've completely disconnected the rear lights to rule out any type of shorts or anything there, replaced and verified all the fuses in the passenger seat fuse box with a test lamp.  Verified the line continuity from wench, head lights, and 4x4 connectors.  So Im kinda stuck at this point. I'm going to go ahead and test all the relays in the passenger side fuse box, but none of those are listed in the manual with having anything to do with 4x4 or the wench so I don't think they will be the solution.  I do see there is a "capstan relay" listed in the wiring schematics on that circuit, but I have no idea where that is (or really what it is, I know a capstan on a boat is kind of a wench so kind of assuming is a translation thing) on the chassis.  I do see something that looks like a rectifier mounted directly behind the wench but not sure what that is either. Which brings me to me last point, I have had malfunctioning rectifier do weird things on other cars so I'm kind of wondering if this might be the case here as well, but I'm not finding anything called a rectifier in the manual.  Any one have an idea where it might be on the chassis so I can test it?   TIA everyone... hoping someone might have some insight!
      By joephus, in Joyner UTV SxS Forum
      • 8 replies
      • 986 views
    • 610 Mule 4x4 White Smoke
      I was riding my 610 when a huge cloud of white smoke came out of the exhaust.  I lost power, I stopped, the engine came back like normal.  I started back to the house, it happened again just for a second.  I shut it down.  Does anyone have a clue what it might be?
      By mcabubba, in Kawasaki UTV SxS Forum
      • 10 replies
      • 2,384 views
