  • ×   Pasted as rich text.   Paste as plain text instead
    • By abernot
      Hi all...I am looking for a reliable mechanic near the last Vegas area to help maintain my 2016 Sand Viper 1100cc.  Any suggestions?
    • By abernot
      Hello,
      First time buggy/UTV buyer here and I have been looking at a 2016 Joyner Sand Viper 1100cc.
      First of all, and overall comments on that particular model or recommendations?  I am a very amateur rider and am just looking to have some occasional fun in the surrounding desert areas of Vegas as well as do some low key canyons and small mountain areas.
      Main question is, what are the options to tow the buggy aside from trailering it?  I have been looking into a tow bar but am finding very limited information on anyone installing a way to connect a tow bar to the rig and tow it that way.  Any insights are greatly appreciated!
    • By 180gtr
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Throttle Body $90
      Starter $150
      Alternator $150
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      That would include....
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
    • By Travis Sparks
      looking to buy joyner complete with title problems ok in tn ky va area 100 miles within knox tn area txt what you got 423 626 0995
    • By Travis Sparks
      can someone tell me where best place to buy 2008 t2 joyner rear end
