Leaking tires, valve stems??
and Canadians have a poster boy narcissist. Only in a nightmare did I ever think he could get elected. Of course the Liberal leader race had the winning candidate step down, I bet a lot of $$$ was paid to him to do this. Second place Trudeau got it. All he cares about is selfies and being noticed.
I can't help but think what other world leaders think of this maniac.
Link to comment
Share on other sites
I found a vid on youtube, it showed all the people who said trump WOULDN't be pres. then is showed the montage of election nights of states calling for Trump, BUT the montage was played to the sound track of 'The william tell overture" or the Lone Ranger theme. I'll have to find and send you a link
Link to comment
Well, back on topic. Soapy water works every time. If it's not working...see above. If it's not working, then you need to change tactics. It WILL work. I've had problems before, try using more pressure for the test. It's not gonna hurt the tire to use 30 lbs. or so for the test. If needed, remove the tire, hose it down. Get it clean. Then soak it down with soapy water. Wait approximately 2 minutes...look for small foam spots. They'll be about the size of a dime, or quarter. There's not always a big bubble to help find the hole. Slow leaks are tough sometimes, but there's no leak that's too small. Don't forget to soap the stem, and the Schrader valve also. Side note... Tire shops don't typically want to fix these type tires. So have them find the leak, if needed, mark the spot, then have them break the bead. You patch the hole! It's the easiest way! But you really need to know before hand what you're dealing with. Good luck!
Link to comment
Just saw Kenfains post. I tried the soapy water but it was a windy day so didn't work well. I always spit over the valve to see if it's leaking and for good measure replaced the core. It's a slow leak, I may well use Travis suggestion of stop leak even though it can unbalance a tire somewhat.
So far I've been chasing my tail trying to find the leak. The Polaris doesn't have 15 hours on it yet. I forget that even new vehicles can have problems, ones even more annoying then regular wear issues.
It still bothers me that the valve stems can be easily rotated in the rim. Anyone else have valves that rotate but don't lose air??
Link to comment
found the leak. Should have done this first (as usual). I overinflated the tire and heard the air leak. I've never seen a small piece of crushed limestone puncture a tire before but there it was a small knife tipped shaped piece of limestone stuck into the tire. What are the odds????
Link to comment
    • By buckrub
      Hey guys! Newbie here. I'm an old man who's better with plowing a mule (4-legged kind) than these newfangled beasts. I, and a friend of mine, just bought new Coleman sxs and are having to finish the assembly. I've been reading on this site and I'm falling on the mercy of you experts. The only way I'm an expert is that an "ex" is a has been, and a spurt is a drip under pressure. LOL First off, the 2 buggies have no ignition switches. They seem to mount on the dash, not the opening in the steering wheel shaft cover, so we ordered new ones that are supposed to fit. They are 8 inches long, and have a 4-wired white plugin which is slightly rectangled when looking at the end of the plug. The trouble is there's nothing to plug into. There is a three-wire grey plug close enough to reach the four-wire plug, but of course, they are not compatible.
      Secondly, the blinker, light, ect. unit on steering wheel just spins around when touched. I see no way in heaven or earth to secure it. I've looked at a diagram on the Powersports site, but can't detect how it mounted. Fellows I'd be so grateful for any help with this. Me and my mule will even plow your garden for free, for your help. LOL
    • By Nathon S.
      I have a Bennche 700 EFI Bighorn. I’ve recently been unable to get it to start. After a little troubleshooting I realized my fuel pump was not pumping fuel. This weekend I emptied the gas and replaced it with new. I replaced the fuel pump, fuel filter and fuel injector. I also replaced the battery, spark plug and made sure all my fuses and relays were good. I have confirmed that the float on the fuel pump is not obstructed. The UTV is about 12 years old and has less than 100 hours on it. It has not run in over a year.  Not sure whats going on?!? After doing a little reading I'm leaning towards it being an issue with the ECU or perhaps a faulty wire in the wiring harness. Anyone have any ideas on where to start looking or what I could be dealing with? Any help is appreciated, thanks in advance!
    • By AlphaSerenity
      Hello,
    • By Jon C
      Hello to anyone who reads this. I am Jon and I own J&M Outdoor Power, a very small, small engine repair shop. I was approached by Coleman about 6 months ago to become one of their Warranty Centers.
      I recently received 3 different UT400's and a UT500 all with similar issues. These units range from 2 months to 2 years old. Customers state that the unit(s) was/were running fine, then heard a pop and a loss of power, two would no longer start. The two that would run would not achieve normal operating speed (around 20mph I would say) without redlining the RPMs. I quickly found that the Valve lash on each unit had become too large on some(both intake and exhaust) and too tight on one(just intake).
      After setting the gaps to .005(I found multiple different people suggesting bigger and smaller gaps, but no definitive Coleman Spec number yet) every unit starts, runs, and achieves top speed without issue.
      I don't know how many others have come across these issues, and I wanted to get something out on the web for others in the same predicament.
      Please let me know if you have had similar issues.
      Edit: I realize that this will not be a fix all solution for this issue, as the oil level and condition should be verified before moving to the valves. Many times improper oil conditions will cause valve lash to change. These units all have good oil and proper oil changes.
    • By Robert B
      Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
