Cub Cadet Diesel UTV key on no lights and wont start
By Steve Toney
Hello, my name is Steve and just signing up. Bought my first UTV yesterday. It is a Massimo T-Boss 550.
By SafeSledBryan
Hey guys! My name is Bryan and i am the owner and creator of Safe Sled. Not some crazy corporate backed recovery product, but just some guy with an idea.
4 years ago, I suffered 11 strokes, and am now 50% paralyzed on the left side of my body. I am unable to work a normal job anymore. I was working on the sled 2 years before this all unraveled. My wife told me to keep working on it since i was pissing her off staying home and doing nothing.
I still plan on improving and implementing different ideas as the product’s revenue continues to grow.
if the sled is appealing to you, please check out my website, safesledoffroad.com
Safe Sled Website
By CBS
Greetings from Southern Illinois. My name is Bruce and I currently have a Hisun HS550 Performance Rural King. I have had nothing but problems with this unit replaced so many parts of it and of course, it stopped working and will not start again for about the 3rd or 4th time since 2018 it only has a little over 500 miles and has cost me a bunch of money and headache and the Rural King where I purchased it has a repair man who is certified to work on HISUN but he charged me a little over $600 to repair it once back a few years ago and when I got it home after it being in his shop for over 2 weeks the thing worked for a very short time but when I went to start it the next day it was the same thing and they wouldn't check it further without me paying for service, labor, and parts and I went around and around with them and since there aren't any dealer service centers for Hisun near me and even most of them can't get to it for weeks to months and it could be at their shops for months as they tell me they have problems getting the parts needed from Hisun to fix these giant paper weights. Oh, and you can't buy a scan tool (code reader) Delphi 190121 unless you are one of their dealers and I can't find any other scanner tool that works with it except the Tiny Scan Tool which I purchased and it will work if I could find the correct adaptor cable and connector to connect the Tiny Scan to the diagnostic port on the Hisun HS550 Performance Rural King. Yep, I pretty much have been screwed every which way that can happen with this machine. I am disabled, have cancer, and am on a fixed income so I need help if anyone knows what the connector is called (type or part name) that will plug into the diagnostic port to get my scanner to work it is a 6-pin connector and I hear it only has to have 3 wires connected to it.
By JFC
I have a 3500LB Winch that only runs in one direction. Inward but not Out. Replaced the solenoid module. Makes "click" when I push the "Out" button and the motor tries to spool out but then stops and begins to "click". Does anyone have suggestions what I should try next?
By skittle021
So I've got a Hisun 550 that I was doing some work on that required removing the CVT and it's housing. Upon attempting to reinstall the clutch, sheaves, etc, I found that the belt no longer fits - it's far too wide. None of the parts have been replaced, they're all OEM. Exactly the same parts as what I took off a few weeks ago.
To be more specific, my belt is 1.25in wide, but the gap between the clutch and the primary sheave is only 7/8in wide. I'll include a few photos to explain.
Has anyone ever experienced such a bizarre problem? Any help at all would be appreciated, I've been stuck on this for a month. I'm open to just about any suggestion.
Photos:
