HELP! Cylinder head Kawasaki MULE 550
Travis
I found a video, where the guides where uneven, and the tallest one wasn't letting the intake go down far enough cause the top of the valve  spring kept hitting the guide...
I think we can call this case closed. Verdict i believe is. The tallest is the guilty party. What do you think gentleman of the jury :)    ?
Link to comment
Share on other sites
Just looking at the link. I'd say put the clips on, and drop em in. Well lubed. They're the same part number, so they'll be the same height and everything else. They'll drop all the way down till they bottom out on the clip. If not find out why.
Sometimes just taking something apart does the trick. When you put it back together, it just works. Don't even know why it worked. It just does! But not always, so there's that.
The good news is that this WILL work!
The bad news is that I'm hanging it up for tonight. You keep at it, and when it's right you'll know it. Don't be afraid of pulling it back out. The spring probably sits on top of the clip, to hold it all down.
Link to comment
It's too early to throw in the towel just yet! The buggered up guide could probably have the rough spots dressed out. Or just replace the guide. If it's still in the head, then you could probably get the tool to remove it. That tool will also help replace the new one.
As long as the head itself didn't get any real damage then nothing has changed, just a setback.
Link to comment
I contacted Our local machines shop, Ted's Engine repair, he said he's not 100% sure if he can do it, since it is a smaller head. I m gonna take it to hm tomorrow and see he can, take em out.
And then what i'll do if he can take em out, i ordered a new guide (s) because they wore past the service limit (measured today), so i'll have new ones he can put in too.
Link to comment
Sounds like a plan, but now you're adding the amount that Ted's charging. So as a learning experience, you've got to consider that. Will everything just work, when finished? Remember buying the whole thing new, it's a finished product.
This is why I suggested that you eat the seventy bucks in the first place, and go new. What other problems are waiting to be found? Just to be clear, I really want you to get the experience, but there's always a price to pay. Typically, it's having to tear back into that motor. But that's all a part of learning this stuff. It's a skill, and knowledge that will serve you well in many other fields, as well as mechanics. So my recommendation is to keep going at this point. As a point of pride you'll be more satisfied with the end result by doing it yourself. You'll be so glad you stuck it out in the end. Even if it doesn't work out right away.
  So many times we just end up selling a failed project, but that knowledge can't be lost. So maybe the next project gets the satisfaction. Either way you're better off having finished this yourself.
   Wish I could say that the chicks really get into mechanics! But unfortunately that's not the case lol. Even wives don't appreciate it, they just expect it. So this project is investing in yourself, and it's a worthwhile investment.
   It's gonna be great!
Link to comment
Yeah, My brother, and a friend of ours have used Ted's for LOOONG time. Always reasonably priced. I called and they said, he has the tools to remove/install, but  since it's a small utv he might not can do it.
But i have a back up company,  Power Toys of Texas, they said they might could do it too.
New head was 200, before shipping and tax.
When im done, im taking it to our mechanic and he said he'll be more than happy to inspect my work.
I could make  a calendar. :)   :)
Link to comment
3 minutes ago, Travis said:
I figured the 30 dollars would be cheap insurance against me doing it, and messing something up worse. Let the Pro's do it, Unless you REALLY know what your doing.
@vaughn Ever watch "Taryl Fixes All" on youtube. Pretty hilarious!
Smartest statement I've heard today. As Clint Eastwood said "A man has to know his limitations."   Valve jobs are not for the inexperienced in my book.
Link to comment
    • By aefron88
      Since I've seen some questions on this I took some pictures and will provide instructions on a valve adjustment for the UT400. This should be the same for the 550's and other various Coleman/Hisun single cylinder models with the cylinder slanted aft.
      I have seen several people ask of it is really necessary, and read several reports of valves being out of adjustment from the factory. My valves were .004" intake, and .010" exhaust with about 5 hrs on the machine.  I've seen different numbers thrown around for factory spec, but I decided to go with 0.005".
      This is called valve lash. What is is is a gap between the rocker arm and the valve then the camshaft isnt opening the valve. Why does it matter? If it's too large the valve doesn't open all the way, if it's too small the valve dosent close. This can cause valve damage (overheating) as well as loss of engine power (burned fuel is going out exhaust rather than pushing the piston dow).
      Tools required : 5MM Allen wrench, 10MM box wrench, needle nose pliers, flat feeler gauge set, rags
      First you need to remove the fan cover on the passenger side. There is a cooling vent hose on the back side, remove the hose clamp and slide it off. From there there are 4x 10mm bolts holding the cover. The forward ones can be accessed from under the seat.
      Next remove the spark plug from the drivers side. Carefully wiggle the spark plug wire off. Grip it as low as possible and give it a little twisting motion as you pull it off to help free it. Its a tight fit for a socket, but there is a sheet metal wrench in the toolkit that fits it. Unscrew the plug and set it aside. This allows you to spin the motor over freely with no compression to fight. When you reassemble this is a good opportunity to switch to an NGK iridium plug for better performance/less fouling DR8EIX)
      Next you need to remove the intake and exhaust valve covers. The intake us the forward one. There are 3x 5MM Allen screws to remove. The Exhaust is the rear with 2x 5MM Allen bolts. Both covers have O-Rings instead of gaskets and are reusable. When you remove the rear be careful and use your rags as there will be oil that drips out.
      Next up we need to spin the motor over to top dead center. Grab each rocker arm and give em a little wiggle up and down. Spin the engine over by grabbing the fan with your other hand. Spin the engine over until both rockers have some wiggle and are loose.
      Once both rockers are loose slide the feeler gauge in like shown above. Try different feelers as needed to determine your starting spec. You should feel some drag but still be able to move the feeler without too much force.
      If you need to adjust, use the 10MM wrench to slightly loosen the locknut, then with the correct feeler gauge in place, tighten the top square nut while wiggling the feeler in and out. Once you have it right you need to tighten the 10mm lock nut without moving the square head bolt. Once the lock nut is tight recheck the clearance.
      That's it, button everything back up and make sure you have it all reassembled before running it again.
      If you find this helpful give me a thumbs up or comment. If you have any questions or need more help let me know. If there's interest maybe I'll do some more of these
    • By azdesertdog
      A desert camp trip we took at Christmas in the desert
    • By mcraigchr
      I realize that many of you do not have diesel machines.  For those that do, this is for you:
      Just wanted to post my experience this past week.  Here in Texas, we had pretty good dip in temps.  For 4 days it did not get above 25.  At night, it was single digits or close to it.  I always put Sta-Bil fuel stabilizer in the storage tank (30 gallon).  And up until this tank I was using Power Service (white bottle) for anti-gel.  Never had an issue.
      This tank, however, I switched to Stabil All season (anti gel).  It is supposed to good down to -40.  Zap.  That is a big fat lie.  I put in twice the amount called for in the instructions.  Result was less than optimal.  I drove the SxS 100 feet (to go get the mail) and it died.  I looked at the fuel bowl and it was a cloudy, wax substance.  So, the Stabil did not work.  That said, I'm not sure that I ever tested the Power Service in the same manner.  So I am not saying that one is better than the other.
      What are your experiences?  Are these products inferior?  What do you folks in the northern states / Canada use?  Am I missing something?
      CC
    • By Michael Flippin
      I have a 2023 T-Boss 410. The starter is just spinning but nothing is turning over. It was working fine and just stalled. Tried to restart and starter just spins. Thought maybe the interior of the starter broke. Ordered and installed a new starter and it does the same thing. You just hear the starter spinning but does not seem like anything is catching. I checked the gear the starter engages and that is clean and turning freely. Any idea what the issue could be?
    • By johnpeter
      2022 Polaris Ranger Northstar Ultimate Custom Sema Show built On Ebay
      https://www.ebay.com/itm/225944675988?
