Lights for 2510 Mule
nybuckboy
On 9/1/2017 at 8:15 PM, nybuckboy said:
Anyone know how I can upgrade the lights on my 99 2510 Mule ?
If you're thinking of adding more power to the existing headlights, you're likely out of luck, without extensive modification. But I'm no expert.
  I'd recommend a light bar. They've got some really nice aftermarket stuff out there. They come in all sizes and shapes. Installation is usually plug n play.
Link to comment
Share on other sites
At 120w of power consumption, it'd have to be used only while the engine is running. Just for comparison, my mule 3010 has 50w stock lights, and they don't perform well either. That thing would pull the battery down in just a couple minutes, possibly leaving you stranded. I'd suggest splitting up the task, if you want heavy duty lighting. So you've got to figure out exactly what you want to accomplish. Are you just lighting the trail in front? To the side also? To the rear? Are you lighting the cargo area also? A work area light?
    You'll need a heavy duty rocker switch panel, and several smaller lights, or bars. I'd run em through an additional fuse box. I'd also suggest upgrading the alternator, if it has one. And maybe adding a back up battery.
    This way you can turn on only what's needed. The  job would be cleaner from a maintenance/trouble shooting aspect. And the effect would have a much better cool factor, IMHO.
   Upgrades like this can be expensive. The easy solution is to just get a couple of forward firing led lights. Our Toyota forklifts at work, have what you need. Check out the newer models of these locally, or on the web. They aren't powerful enough to replace the stock lights, but to supplement the total.
I can also tell you that the color of light is important, to actually recognize what you're seeing. Led lighting CAN do it. But the technology has barely made it to the flashlight market. Extremely white light gives a washed out appearance to stuff. You want a more yellow light. It's a huge difference, but you have to see it firsthand to appreciate it.
Link to comment
47 minutes ago, kenfain said:
Not to mention the skeeters
Oh yeah!! Lately the county has been flying the C130 Spraying. So in 60 years I'll have some form of cancer or disease that i can make money off of by suing them! Lol :)
Last winter, we bought a little 5x5 greenhouse to keep our plants in, in the day time, it would get in the upper 90's in the green house, but the humidity was soo thick, U cant breath!
Link to comment
    • By johnpeter
      2023 Can-Am Maverick Sport XMR 1000R RED TITANIUM On Ebay
      https://www.ebay.com/itm/156096225938?
    • By johnpeter
    • By Coleman400
      Hey all. I need to change my plug in my ut400 and I remember seeing people in here saying to get a certain one that was better than what it came with. What was it?
      Also I need to do an oil change. Are the tractor supply oil change kits ok to use?
      Any help here is appreciated!
    • By johnpeter
    • By Irons
      Hopefully this helps somebody because I couldn't find any info on this runaway condition.
      Drove 1/2 mile to the gas station and when I started up to leave the starter stuck on. Turn key off starter is still running~! Limp it home wondering what the heck to do, get it in the garage and pull the negative battery terminal to get it to stop. Whew, WTF?
      Calm down and start checking things, starter is hot of course but nothing is smoking and nothing smells burnt. Pull battery cover off and start checking wires from battery to relay and relay to the starter. OK good nothing is hot, nothing is crispy and nothing is melted. Probably smoked the starter though. If this had happened to my wife and I wasn't around the machine would have run until the battery died and probably melted down/burned.
      I'll get to the point to save you folks some time and trouble. Because this is a kymco machine you need 2 different Kawasaki parts to make this repair, and information is scarce to say the least. The switch and a sub harness to connect it to the machine's plug.
      Everything works now, but the starter sounds horrible so I'll be changing that too before spring.
      Good luck out there and hopefully this is just a freak occurrence, but if I were you I'd get rid of this kymco part and put the Kawasaki replacement in now.
      Switch, Magnetic is part number 27010-0767
      Sub Harness Start Relay is part number 26031-Y034
