Headlights Cub cadet 750 crew
By Gary Odom
I bought a tracker 88sx crew in 2023. It has a whishing noise coming from the front end. Starts out low and gets louder as speed increases. Took it back to the dealer and they said it was normal on this model. Any suggestions as to what may be causing this.
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
By Paul409
Have a Hisun 750 only 700hrs 21 model. Never had issues went to start it and there's a clicking sound under the seat I'm assuming it's the started relay. I for the life of me cannot find the starter, is there a way to test the relay.
Thank for any support
By bikermike
Since it is a royal pain to close the front hood, I went to add a charger wire so I don't have to worry about the hood, I found the screw on the positive post rusted . this utv is 11 months old. and since it's a Philips head, it was impossible to loosen . had to use vise grips.
replaced the screw with an hex bolt
