  • Similar Forum Topics
    • Hisun 750 crew 2016
      I have a 2016 750 crew (it is a Cub Cadet but same machine). It has 108 hours, 49 miles. Basically new, but I got it used with 22 miles on it. The guy said it was too big, and that he wanted a RZR. It ran great for a little over a year. It then developed a rough idle and won't wind up to get past about 20 mph in high range. I have tried countless things, and I keep coming back to overfueling. It doesn' seem to be throwing a code.  I have done the following... Spark plug (multiple times) Check, clean air filter  Sprayed brake clean around intake while running (to be sure it isn' sucking air). Checked valve adjustment Replaced fuel pump assy., after breaking it trying to remove to check in tank filter. Checked wiring and connections Checked/cleaned spark arrestor screen Replaced fuel, trying different octane.  Checked compression. Compression should be 1200 kpa,  mine was between 700 and 800 kpa.  Also noticed oil had been increasing and is now milky looking. I figured gas in oil due to overfueling. Dad said milky or foamy meant coolant in oil so we figured blown head gasket. So, we put a new head gasket on it. Old one didn't look blown. Valves were tight like new, could still see cross hatch marks in cylinder wall (like new as it IS still new!) Put it all back together, torqued bolts properly etc... no change. Still runs poorly, compression still low! I don't think it is a compression issue. We pulled the rocker cover back off to check out the automatic compression release that we had noticed on the timing chain  sproket on the end of the camshaft. It seems to be working properly. Then a lightbulb went off. "Automatic compression release" appears to slightly open an exhaust valve... when?... while cranking engine to start. There is no way that we're going to get 1200 kpa compression (unless I were to back that exhaust valve way off)! I may try that when I re-install the rocker cover.   Anyway, I'm pretty convinced that it is fuel in the oil, and that it is over fueling like I originally suspected. But how do I know the cause?? Book says over fueling could be caused by Air Pressure sensor, o2 sensor, Solar Term door position fault, or ECU program error or damage. Those are some pricey parts.  Any input??
      By Budmanbiker, in Hisun UTV SxS Forum
      • 9 replies
      • 1,054 views
    • Hisun/Massimo 400 Fuel in Airbox
      Hi,  Just purchased a 2015 Massimo 400 EFI. While I was cleaning the air filter sponge I noticed fuel was dripping out of the air box. Any ideas where this may be coming from?  Since it has electronic fuel injection I wouldn't think a carb float would be stuck or something like that.  Any advice is appreciated.
      By Kannon09, in Hisun UTV SxS Forum
      • 1 reply
      • 168 views
    • 2008 hisun rear axles
      Are the yamaha rhino rear axles the same I have a 2008 big muddy made by hisun and the rear axles for hisun are expensive and the rhino is about half the price? Thanks if anyone has info
      By Charles Newton Jr., in Hisun UTV SxS Forum
      • 1 reply
      • 220 views
    • Wanted: Trooper Axle Parts
      I am interested in any old trooper axle parts you may have lying around. Please let me know if your want to sell them.  Backstory: Hey everyone. Last trip out to moab I climbed a wall on poison spyder Mesa while 2 rzr xp1000's and three can am x3 xrc's watched me and didn't dare try. After doing it once I pulled around to show them it wasn't a fluke. One on the can am x3 xrc drivers just looked at me and said "that's steep". On the second try I spread the bell on the left rear axle. I made the climb but now the inner cage slips inside making a loud popping noise as twisting the boot. I mainly just need the inner bell but I am interested in anything you have.
      By 2scoops, in Joyner UTV SxS Forum
      • 1 reply
      • 241 views
    • Slow 2017 HiSun Strike 250
      Guys, I need some expert help..  I just bought a 2017 HiSUN Strike 250 and was real disappointed to find out that there is an electronic spark cut out at 30 mph.  Every article that I read prior to purchase said that the unit could hit 45-50 mph with the pedal stop screw removed.  Not the case with my machine.  Never bothered to ask the dealer before purchase, so it is my fault...  My guess is that HiSun got some flack about thier "kids" machine doing 50 mph and were forced to add the electronic limiter..  Can anyone verify that previous to the 2017 model that the machine can actually could do 45-50mph with the just pedal screw removed?  If so, what RPM is it at when doing 45-50 mph.  Maybe I can get an older version of the Delphi ECU, assuming that is where the spark cut out is located...? The machine is definitly full featured, but as you all mention, needs to be gone over after purchase.  A-men to stipped screws, and if you suffer from a crazy squeak sound that sounds like chains dragging, check the torque on the suspension a-arms and shocks.  Ours were so tight, we could barley get them loose and the suspension would not move, essentially zero travel.  Once we lightened up the torque, greased the plastic bushings, and added blue threadlocker, the suspension actually worked and all the squeaks went away.  Also have same problem with the shift linkage rubbing on pipe and also pipe rubbing on chassis.. This weeks project! Any help on the speed would be awesome!
      By Fun Dad, in Hisun UTV SxS Forum
      • 47 replies
      • 3,776 views
