  • Similar Forum Topics
    • Wanted: Trooper Axle Parts
      I am interested in any old trooper axle parts you may have lying around. Please let me know if your want to sell them.  Backstory: Hey everyone. Last trip out to moab I climbed a wall on poison spyder Mesa while 2 rzr xp1000's and three can am x3 xrc's watched me and didn't dare try. After doing it once I pulled around to show them it wasn't a fluke. One on the can am x3 xrc drivers just looked at me and said "that's steep". On the second try I spread the bell on the left rear axle. I made the climb but now the inner cage slips inside making a loud popping noise as twisting the boot. I mainly just need the inner bell but I am interested in anything you have.
      By 2scoops, in Joyner UTV SxS Forum
      • 0 replies
      • 54 views
    • Hisun 250 - Brake Locked up
      Anyone know what is needed to get the piston back in.? Using a C Clamp is not working. Brake locked up and likely smoked my belt too..  Anyone ever changed the pads before?
      By CStrike250, in Hisun UTV SxS Forum
      • 6 replies
      • 89 views
    • Hisun Sector/Vector 250 Service Manual?
      I haven't been able to locate a Service Manual (aka Shop Manual) for the Hisun Sector 250.  Does anyone have one they can share with me?
      I have the service manual for the Strike 250 (thanks Strike250), but I'd like to have the one specific for the Sector/Vector.  Thanks!
      By DigitalDan, in Hisun UTV SxS Forum
      • 4 replies
      • 1,065 views
    • Slow 2017 HiSun Strike 250
      Guys, I need some expert help..  I just bought a 2017 HiSUN Strike 250 and was real disappointed to find out that there is an electronic spark cut out at 30 mph.  Every article that I read prior to purchase said that the unit could hit 45-50 mph with the pedal stop screw removed.  Not the case with my machine.  Never bothered to ask the dealer before purchase, so it is my fault...  My guess is that HiSun got some flack about thier "kids" machine doing 50 mph and were forced to add the electronic limiter..  Can anyone verify that previous to the 2017 model that the machine can actually could do 45-50mph with the just pedal screw removed?  If so, what RPM is it at when doing 45-50 mph.  Maybe I can get an older version of the Delphi ECU, assuming that is where the spark cut out is located...? The machine is definitly full featured, but as you all mention, needs to be gone over after purchase.  A-men to stipped screws, and if you suffer from a crazy squeak sound that sounds like chains dragging, check the torque on the suspension a-arms and shocks.  Ours were so tight, we could barley get them loose and the suspension would not move, essentially zero travel.  Once we lightened up the torque, greased the plastic bushings, and added blue threadlocker, the suspension actually worked and all the squeaks went away.  Also have same problem with the shift linkage rubbing on pipe and also pipe rubbing on chassis.. This weeks project! Any help on the speed would be awesome!
      By Fun Dad, in Hisun UTV SxS Forum
      • 42 replies
      • 2,857 views
    • 2008 hisun rear axles
      Are the yamaha rhino rear axles the same I have a 2008 big muddy made by hisun and the rear axles for hisun are expensive and the rhino is about half the price? Thanks if anyone has info
      By Charles Newton Jr., in UTV General Discussion
      • 0 replies
      • 130 views
