  • Similar Forum Topics
    • Trooper Help
      The Prick from Silver Bullet Stoll my Cylinder Head so Ordered One from China Now i seem to missing the thermostat housing and there two hole i need help identifying  Anybody have parts?? or Pictures of what i need Thanks
      By Racinaround, in Joyner UTV SxS Forum
      • 1 reply
      • 19 views
    • Wanted: Trooper Axle Parts
      I am interested in any old trooper axle parts you may have lying around. Please let me know if your want to sell them.  Backstory: Hey everyone. Last trip out to moab I climbed a wall on poison spyder Mesa while 2 rzr xp1000's and three can am x3 xrc's watched me and didn't dare try. After doing it once I pulled around to show them it wasn't a fluke. One on the can am x3 xrc drivers just looked at me and said "that's steep". On the second try I spread the bell on the left rear axle. I made the climb but now the inner cage slips inside making a loud popping noise as twisting the boot. I mainly just need the inner bell but I am interested in anything you have.
      By 2scoops, in Joyner UTV SxS Forum
      • 1 reply
      • 241 views
    • 2009 Joyner trooper fueling problem
      Fuel pump runs but nothing is getting tô it. I tried putting a vacuum on the outlet hose of pump and it wouldn't pull anything. This machine sat for a year and a half unused. Is there a way to prime the lines?  What could be the cause of the fuel not getting tô the pump?
      By Whisper Snowbird, in Joyner UTV SxS Forum
      • 4 replies
      • 120 views
    • 2009 Joyner trooper valve adjustment
      I need to adjust my valves. But I can't find any specs that tell me the valve clearance. Can someone help me?  1100cc chery
      • 8 replies
      • 112 views
    • 2009 Joyner trooper starting problems
      I have a no cranking issue with my joyner. It has a chery 1100. It will click but nothing after that.  New battery. I tried banging in the starter while holding key in start(old car trick). Now the  starter solenoid won't even clunk. Just hear s click fron the relay now.  My assumption is the starter needs replacing.  Any ideas of other things to check? Does anyone have diese block diagrams?  Got no clue what fuse or relay goes to what
      • 12 replies
      • 190 views
  • Similar Tagged Content
    • By Moody
      I have a 2014 xy1100uel and need to find a transmission/gearbox for this and cannot find anywhere to get parts any help would be appreciated thanks
    • By pulvin54
      Hey all,
      Not new to forums but new to this one. Just picked up a Joyner T2 and looking to make a couple of upgrades. I finally was able to locate a half decent wiring diagram but if anyone has one I'd sure appreciate another one ( the one I downloaded is ok but zooming in blurs the font). I'd like to put a hard top on it. I'm not aware of anyone that makes one. I was just gonna attempt to cut out part of an old truck bed liner. I also need to replace the boots on it and I read somewhere that the boots for a '96 GEO Metro will work? Also, I have no idea what year it is. I've looked all over it and the only thing I've found is the sticker on the firewall behind the driver's seat. It states that this machine meets the 2008 CA emissions standards. Even the VIN plate doesn't have the year stamped on it. Any help would be great. Thanks.
    • By utvwolfpack
      This is a new video we did on our new Rockstar UTV Wolfpack Edition Arms Kit for the XP900 and XP1K. Check it out and let us know what you think!
      UTVWolfpack.com
      Twitter @utvwolfpack
      Instagram @utvwolfpack
      Facebook.com/utvwolfpack
    • By utvwolfpack
      <<<UTVWolfpack.com
    • By utvwolfpack
      <<<UTVWolfpack.com
