  • ×   Pasted as rich text.   Paste as plain text instead
  • Similar Forum Topics
    • 2008 hisun rear axles
      Are the yamaha rhino rear axles the same I have a 2008 big muddy made by hisun and the rear axles for hisun are expensive and the rhino is about half the price? Thanks if anyone has info
      By Charles Newton Jr., in Hisun UTV SxS Forum
      • 2 replies
      • 309 views
    • 2018 HISUN HS500 Wheel spacers Hisun HS500
      Can anybody tell me where I can get wheel spacers for a Hisun HS500?  What other spacers will fit the hisun? Also, will 27-inch tires fit without rubbing? HELP!
      By Mark Floth, in Hisun UTV SxS Forum
      • 1 reply
      • 93 views
    • 2017 Hisun Sector Crew 750 Questions
      Hello, I have a  question that I cannot seem to find the answers for: 1) Where can I download the service manual?  Thanks    Edit:  Talked to Matt over at https://warriorsoffroad.com/ and he answered most of my questions!!
      By coryallen, in Hisun UTV SxS Forum
      • 0 replies
      • 62 views
    • Hisun 700 wont crank over
      Hey guys. I have a 2009 hisun 700 I bought bout 2 weeks ago and it was running fine but was hard to start but once warm it fire rite up  i took the  air filter off and it was nasty so I gave it a good cleaning and it hasn't started since. Its cranking over really slow I replaced the starter. I also replaced the batery. It acts like its not releasing decompression  I found a service manual on line and downloaded it and it said the intake valves setting .010-.015 mm  and exhaust is .015-.020 and they all was set on .008 intake and exhaust. And the timing is set I set the intake to .012 and exhaust to .016 and it still cracks over really slow I'm lost and don't know wat else it could be. Anyone have any ideas.  And help would be great thanks .
      By Wyatt Carneal, in Hisun UTV SxS Forum
      • 5 replies
      • 149 views
    • Hisun 750 crew 2016
      I have a 2016 750 crew (it is a Cub Cadet but same machine). It has 108 hours, 49 miles. Basically new, but I got it used with 22 miles on it. The guy said it was too big, and that he wanted a RZR. It ran great for a little over a year. It then developed a rough idle and won't wind up to get past about 20 mph in high range. I have tried countless things, and I keep coming back to overfueling. It doesn' seem to be throwing a code.  I have done the following... Spark plug (multiple times) Check, clean air filter  Sprayed brake clean around intake while running (to be sure it isn' sucking air). Checked valve adjustment Replaced fuel pump assy., after breaking it trying to remove to check in tank filter. Checked wiring and connections Checked/cleaned spark arrestor screen Replaced fuel, trying different octane.  Checked compression. Compression should be 1200 kpa,  mine was between 700 and 800 kpa.  Also noticed oil had been increasing and is now milky looking. I figured gas in oil due to overfueling. Dad said milky or foamy meant coolant in oil so we figured blown head gasket. So, we put a new head gasket on it. Old one didn't look blown. Valves were tight like new, could still see cross hatch marks in cylinder wall (like new as it IS still new!) Put it all back together, torqued bolts properly etc... no change. Still runs poorly, compression still low! I don't think it is a compression issue. We pulled the rocker cover back off to check out the automatic compression release that we had noticed on the timing chain  sproket on the end of the camshaft. It seems to be working properly. Then a lightbulb went off. "Automatic compression release" appears to slightly open an exhaust valve... when?... while cranking engine to start. There is no way that we're going to get 1200 kpa compression (unless I were to back that exhaust valve way off)! I may try that when I re-install the rocker cover.   Anyway, I'm pretty convinced that it is fuel in the oil, and that it is over fueling like I originally suspected. But how do I know the cause?? Book says over fueling could be caused by Air Pressure sensor, o2 sensor, Solar Term door position fault, or ECU program error or damage. Those are some pricey parts.  Any input??
      By Budmanbiker, in Hisun UTV SxS Forum
      • 9 replies
      • 1,161 views
