Shortening the turning radius on a Hisun Vector 250
Orebonder
Good evening all...
Question?...... Has anyone tried shortening the turning radius on a Hisin? I have the Hisun Vector 250... Which is a blast and perfect for what I need and want. The only thing I would change, now,..is to make the turning radius shorter...mine is about 17 ft. I would think a UTV, side x side would be much tighter.
any thoughts?
John
Link to comment
Share on other sites
  • Alex changed the title to Shortening the turning radius on a Hisun Vector 250
There are a few mechanical issues to address when thinking about changing turning radius. The ability of the OEM steering box/rack. The length of the OEM tie rods, the steering stops built into the OEM spindles. All of this has to be addressed when trying to change the turning radius. You can adjust the steering stops on the spindles, but if the OEM steering box will not allow more movement in the gearing, then there is nothing you can do to get a tighter turning circle. You might try to go with an aftermarket steering rack. You will need to measure the distance from tie rod outer end to the other outer end to try to get one with the same distance in order to have a correct toe in measurement. Making sure the steering shaft will also bolt to the new steering rack as well. Or you will have to cut and weld to make things work. It can be done, but will take some thought.
Link to comment
    • By AlphaSerenity
      Hello,
    • By LindaCall60
      Purchased a 2011 bighorn banchee. Needs motor work. Not sure what. Husband is mechanic but not computer savvy. So, is there a manual that will tell him how to tear this down?  We have down loaded a service manual, but he says it doesn't tell him what he is looking for.
    • By Hugh
      Hugh
    • By Richard shepard
      I have a 2021 colman 400utv engine will start and idle, as soon as you hit throttle to move engine dies and will only start when you throttle it, let off throttle it dies, I replaced the injector and plug still the same, anyone have any other ideas
    • By Kalyla Jackson
      Hey all!
      I'm on a mission to buy my first UTV soundbar as a gift for my dad. I'm aiming for something that offers great sound quality without breaking the bank – my budget is around $250. Right now, I'm considering options like ecoxgear, kemimoto, and boss.
      Does anyone have experience with these brands or specific models that you'd recommend? Any advice or suggestions would be super appreciated!
      Thanks in advance for your help!
