Travis' Mule 550
Readjusted the valves, and again I put some assembly lube along the valve springs, rocker arms, end of the pushrod where it goes in the rocker arm, and across the rocker pin. And for awhile that quited it down a bit......
Another crazy thing, I ch anged the transmission fluid in it, and now the differential works!!!, I went through some mud that I normally couldn't go through EASY!
Link to comment
Share on other sites
I'm going to see if my brother can come look at, he had the head off of his 91 dodge last year, with a ticking sound too.
Although there is probably some difference between a a 6 cyl diesel and 1 cyl. Gas.
One thing I was thinking about, I had to replace the exhaust side valve adjuster stud and nut, ( I stripped the old one) I wonder if that new adjuster meeting with the worn in valve is causing it.....?
Link to comment
You might try to find a leak down tester at the local auto parts tool loan program, and give that a try. Otherwise I'm assuming that there's not any oil leaking around where the cylinder meets the case. And if you pull the dipstick while its running, and oil doesn't come out. Nor is there any oil on the crankcase ventilation tube. That pretty much covers the head gasket.
I'm still thinking that one of the lifters is the problem, but it's a good idea to keep an open mind. If it makes good power, and the plug is still looking good, and as long as it doesn't get worse. I'd just keep driving it for awhile.
Always keep an eye on it, and keep checking the plug. If it's anything significant then eventually it'll start showing signs of what's wrong with it.
  • Thanks 1
Link to comment
Yep, none of that.
I just wonder why or what is causing the lifter to tick, i shined my light down in the bore where the pushrods sit, and there was oil on the end of it and the pushrod...  i measured their diameter and they were both still in spec, and i lubed them up good when i installed them....
It hasn't gotten any worse since it started at all....
Link to comment
Up should be the least pressure. When it starts coming down, that's when pressure is applied. Most engines have some sort of mark that indicates TDC. You might research that. The screwdriver method works too ...usually. The problem with the screwdriver method, is it's a judgement call, and not perfect. But it sounds suspiciously like maybe we're not quite at TDC. Just based on the symptoms, and subsequent description of same.
If there's no marks, at all, then try adjustment of the valves by rocking the engine. Look for the sweet spot, when the slack in the rod appears. Because that's likely where your tap is. Adjust that to tolerance specs. See if that improves the situation.
Link to comment
If there's enough slack for the push rod to spin, then it can take some tightening with no problem. So its worth a try. Just be mindful of the original settings. You don't want to over tighten. A bent push rod would be bad. Just as long as there's the proper tolerance somewhere around the top. Just rock it back and forth, and try to push the feeler guage in while doing it.
Link to comment
if  want to get rid of this tick, I HAVE to go back in, but deeper than I thought.
It appears to be the camshaft bearing, which is NON replaceable. You have to buy a whole new block and sidecover and cam. Around 500 smackaroos for fix. I knew I had to do it before, I was able too, but financially I couldn't afford it.
to replace the engine with say a Briggs or Kohler is 800 at least, to get the right amp alternator, and electric start option.
So I'm going to save my money and order everything I need, and now I know I'll know what I need to do this time.
I will probably start the work when school let's out for summer.
Link to comment
    • By Hugh
      Hugh
    • By JSmojo
      I've been looking at various types of UTVs in the 400-700cc range. It seems that Massimo has a really good price point but I don't know much about their reliability and availability of parts. Been looking specifically at their T-Boss 550. I've heard the parts might be an issue because the network is smaller, but couldn't find much info from owners.
      Here are a few specific questions about them
      1. In your opinion, are the reliable? Specifically, have you hand any parts break that in your mind shouldn't have?
      2. If you had one and got rid of it, what was the reason?
      3. If you don't recommend Massimo, what would you recommend (even if it costs a little more)?
      4. How easy is it to find a place to service them? How easy is it to get parts if you want to service it yourself?
      If you have any other advice, I would appreciate it. I'm also looking at the Hisun Sector 550.
    • By Grizz
      Hello I have a 2022 axis 7004x4 Utv after about 6 months it would start fine but sometimes it would stall and you have to crank it again and it would run fine I am wondering what causes this does anyone else have this problem. Thanks
    • By Jacob E freeman
    • By Nickie Watts
      I have a Hisun Strike 1000 I have been trying to get going, it has only 39 hours on it, so I can only assume it has been sitting for a long time.
      The issue is it is losing spark to both coils after 20-30 seconds of running, doesn't matter if it's WOT or Idle, it will shut down.  What sends signal to the coils to fire? It has a crank sensor, I was thinking a CDI box, but I have not found one of those on the machine.
      The rear end was busted on it when I got it, So I ordered a new one and installed it only to run into this problem. I can only imagine the problem has happened over it sitting so long and not being driven.
      I originally thought it was a fuel problem, so I checked the injectors, throttle body, o2 sensors. Discovered the heating element in one of the o2 sensors was bad, so ordered both and also replaced both injectors just to be sure, then discovered it is only losing spark.
