Similar Forum Topics
Joyner Trooper Power Steering
I had been wanting to install power steering on my T4 for years so I went to the salvage yard last weekend and bought a complete column (minus airbag) out of a 2009 Nissan Versa for $125 with the ECU. It was a fairly simple install. The long shaft that fits to the Joyner steering rack actually fit perfectly into the Nissan column. Had to weld up a U joint on the Nissan column to make it a straight shaft and fab up one simple bracket. Connect power and ground plus a switched 12v and now I can steer with one hand!By mixfixdave, in Joyner UTV SxS Forum
- 3 replies
- 220 views
07 Joyner sand viper engine & transmission swap
Has anyone done an engine & tranny swap on an 1100cc sand viper?By Vernon Brown, in Joyner UTV SxS Forum
- 9 replies
- 166 views
best place to buy 2008 t2 joyner rear end?
can someone tell me where best place to buy 2008 t2 joyner rear endBy Travis Sparks, in Joyner UTV SxS Forum
- 4 replies
- 90 views
Looking for Joyner 600 or 800 transmission
Hey guys as the title says. I'm looking for a transmission for my 2008 Joyner 800cc mini viper. Let me know if you have anything available, thanks!By zebediah101, in Joyner UTV SxS Forum
- 1 reply
- 57 views
2009 Joyner trooper fueling problem
Fuel pump runs but nothing is getting tô it. I tried putting a vacuum on the outlet hose of pump and it wouldn't pull anything. This machine sat for a year and a half unused. Is there a way to prime the lines? What could be the cause of the fuel not getting tô the pump?By Whisper Snowbird, in Joyner UTV SxS Forum
- 8 replies
- 219 views
