Similar Forum Topics
2011 mule 610 fuel in oil?
Dipstick shows pale color, dont think its water, smells like fuel, oil changed one week ago, level is very high. First I thought it was water condensed into the oil...but someone pointed out the smell, and it doesn't look white-milky. And a half qt or so in one week? So is it possible to get fuel leaking into the oil?By Muledaze, in Kawasaki UTV SxS Forum
- 8 replies
- 115 views
Starting a shop for Joyners
We would like to add a repair and parts shop to our shop in Southern California for the Joyners. How many Joyner people in the area do we have that own Joyners?By WCF, in Joyner UTV SxS Forum
- 26 replies
- 732 views
2017 Hisun Sector Crew 750 Questions
Hello, I have a question that I cannot seem to find the answers for: 1) Where can I download the service manual? Thanks Edit: Talked to Matt over at https://warriorsoffroad.com/ and he answered most of my questions!!By coryallen, in Hisun UTV SxS Forum
- 0 replies
- 67 views
Massimo 400 Fuel in Airbox
Hi, Just purchased a 2015 Massimo 400 EFI. While I was cleaning the air filter sponge I noticed fuel was dripping out of the air box. Any ideas where this may be coming from? Since it has electronic fuel injection I wouldn't think a carb float would be stuck or something like that. Any advice is appreciated.By Kannon09, in Massimo UTV SxS Forum
- 1 reply
- 235 views
Slow 2017 HiSun Strike 250
Guys, I need some expert help.. I just bought a 2017 HiSUN Strike 250 and was real disappointed to find out that there is an electronic spark cut out at 30 mph. Every article that I read prior to purchase said that the unit could hit 45-50 mph with the pedal stop screw removed. Not the case with my machine. Never bothered to ask the dealer before purchase, so it is my fault... My guess is that HiSun got some flack about thier "kids" machine doing 50 mph and were forced to add the electronic limiter.. Can anyone verify that previous to the 2017 model that the machine can actually could do 45-50mph with the just pedal screw removed? If so, what RPM is it at when doing 45-50 mph. Maybe I can get an older version of the Delphi ECU, assuming that is where the spark cut out is located...? The machine is definitly full featured, but as you all mention, needs to be gone over after purchase. A-men to stipped screws, and if you suffer from a crazy squeak sound that sounds like chains dragging, check the torque on the suspension a-arms and shocks. Ours were so tight, we could barley get them loose and the suspension would not move, essentially zero travel. Once we lightened up the torque, greased the plastic bushings, and added blue threadlocker, the suspension actually worked and all the squeaks went away. Also have same problem with the shift linkage rubbing on pipe and also pipe rubbing on chassis.. This weeks project! Any help on the speed would be awesome!By Fun Dad, in Hisun UTV SxS Forum
- 47 replies
- 4,037 views
