Just bought a 2020 tracker 800 sx crew
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
By donny
Hello I am new here but have had this machine for about 5 years. I am having issues with it surging and sometimes sounding like a small backfire thru the intake. When putting in low, high or reverse it will struggle then go full power then struggle. It will only do the small backfire thing while in neutral reving it many times. Once in awhile it will throw a check engine light.
Parts replaced/checked:
I have checked the valve lashing, timing and adjusted. Parts replaced are the coils, spark plugs, injectors, fuel lines, fuel pump, IAC sensor, TPS sensor, throttle cable, speed sensor, primary and secondary clutch and belt.
By Abermp
I have a DesertCross 800 that doesn't want to stay in low, it pops out when I let off the gas. No problem with the other gears. What do I need to do? Thanks.
By Gary Odom
I bought a tracker 88sx crew in 2023. It has a whishing noise coming from the front end. Starts out low and gets louder as speed increases. Took it back to the dealer and they said it was normal on this model. Any suggestions as to what may be causing this.
By Dave N.
2020 Massimo Buck 400 - Won't start. Can hear the starter spinning, but motor never turns. Relay? Starter? Worked fine one day and not the next. Thanks for any help you can provide.
