By
aefron88
Even though we get actual engine error codes to display on the dash, sometimes we have âpending codesâ (not yet confirmed by the ECU) or other intermittent issues that are hard to diagnose, for example a poorly connected sensor that may give intermittent false readings, or a sensor thatâs putting out bad date, but not bad enough for the ECU to realize.
The setup requires 2 cables, which are available for around $25 combined, a PC with a USB port, and some charityware software called âHUD ECU Hackerâ. This gives the same functionality as the $300 dealer code scanner for a fraction of the price.
Delphi ECU Info & Overview (This post)
System setup & use
Delphi ECU Info (Skip ahead to the next post if your eyes glaze over technical details)
