  • ×   Pasted as rich text.   Paste as plain text instead
    • By bmoody4550
      I recently got a 2006 Joyner 650cc Commando. It was not running when i got it.
      I put a new fuel pump and alternator and is up and running.
      My problem is when I originally got it started it seemed I didn't have 1st gear.  I was able to get it moving from 2nd and was sure I got it into 3rd.
      In my process of diagnosing the first gear issue and I realize I have first gear because it is where I thought 3rd gear was. But now I don't seem to have 3rd or 4th gear.
      The shifter itself seems sloppy and needs a little rehab if that is possible. Replacement available?
      Cables are worn so I don't know if they have too much play to properly shift. Can't seem to find any cables available to replace.
      Can someone tell me which cable should be first and second and 3rd and 4th? One is black and the other is red.
      Ultimately it may be a transmission problem internally.
      As long as I have 1st and 2nd the machine will work for me going through the woods picking up wood.
      Any help is greatly appreciated.
      New to this if you can't tell.
    • By Terrypenton
      Bought this machine a couple years ago and the gages didn’t work.  I have troubleshot this thing numerous times to no avail. Thought it may be a common ground so I individually grounded  the gages, didn’t work.  I have tested the sending units.  All have some resistance that changes as the engine revs or gets warmer.  Please help me.  Thanks in advance
    • By David Dewayne Reel Sr.
      Hi, I was hoping to find an "in-color" diagram, at least, of the wiring from the speedometer and where all the wires are connected.
      The entire wiring of the entire side-by-side would be wonderful!!!
      I purchased a used 2008 Joyner Commando 650 2 seater from an individual and they butchered the wiring...something has come lose and I cannot for the life of me tell where it is supposed to connect. It is a ground wire and is till connected to the frame but I don't know where else it is suppose to connect.
      What makes me think it goes to the speedometer is that when it came lose, the speedometer immediately stopped working.
      If anyone can help me with this, I would appreciate it tremendously. There is nothing on Joyner's website...and I already looked on YouTube to no avail...might be something there but I could not find it...
    • By josephb
      Couldn't find in parts and pieces any aftermarket front lower ball joints for an 09 Renegade. Thanks in advance if you can help.
    • By MudAndSand
      I've blown a head gasket and am in the process of removing head. Does anyone know if the timing chain can be removed with out taking the sprocket cover off? I've found a light colored link but don't see if it can be tapped apart there or not. Reluctant to do any more tear down than I need to. Thanks.
