Hello all. I have a 2005 Joyner sand spider 650 with the dreaded broken output shaft on the transmission. I got ahold of a 2007 joyner commando 650 for cheap that had a bad motor but a good transmission. I got it because everything i read said that the transmission would work but it seems that it will not. Due to the commando being 4x4 it has a selectable locker and a small ring gear using a "idler" gear to turn the ring gear which make the output spin the wrong direction. Is there any way that I can make this thing work? I really dont want a commando,  I like the buggy but if the trans wont work then I can only put my motor in the commando. Any help would be appreciated. I have the ring gear from the original trans but the shaft is broken and the shaft from the commando wont fit the ring gear it doesn't appear.
    • By 180gtr
      Parting out a rolled Sand viper 1100. I will list some of the parts I have, otherwise ask me if there is something specific you are looking for. I am selling everything I have for $800. I am located near Glenwood Springs CO.
      SOLD ITEMS, I do not have these items.
      Wheels
      Tires
      Engine
      Transmission
      Axles
      Shocks
      Control Arms
      Things I have....These all came off of the running engine. I have video of it running if anyone needs to verify that.
      Throttle Body $90
      Starter $150
      Alternator $150
      Fuel rail, injectors, fpr $100
      fuel pump $70
      Map Sensor $50
      Full set of Guages $150
      Exhaust w cat, O2 SOLD
      Ignition Coil - SOLD
      Wiring harness and ecu SOLD
      Radiator, shroud, elec fan, overflow tank $200
      Fuel tank w sender $150 Has dent at base of fuel neck, no leaks
      I have a box full of misc bolts, nuts, etc.
      I will sell the Chassis or Frame alone for $200. The chassis is in pretty good shape, needs some cage repair and 2 areas straightened where control arms mount. If anyone had an automotive frame machine it would take a few hours.
      That would include....
      Brake calipers, lines, pedal, master cyl, E brake assy,
      Steering shaft, wheel
      Ignition switch, key
      Light bar frame, 2 lights
      misc hardware, spindles
      2 hubs, rotors
      Engine mounts
      Throttle pedal, cables
      Shifter, cables
      Clutch master, pedal
      I am sure I am forgetting something.
      I am parting this out of ebay right now, I just picked up another project and could use the room. No I will not take less than $700 for all of it or $200 for the frame. I do not need to sell it, I will make far more parting it out but would like the extra space in the garage.
      If interested I also have an 07 1000rr engine setup I would sell with the buggy for $650.
    • By Jeff freeman
