My 2022 Coleman/Hisun UTV 400 steering shaft has a couple of U-joints and angles to help get it down from the steering column to the rack.  Today, my son who drives it most came in and said that it wouldn't steer and that he could turn the steering wheel but it doesn't turn the wheels  I investigated and noticed that the bolt that clamps down the upper part of the steering shaft onto the lower one before the first u-joint in the steering shaft had fallen out.  We haven't been able to find it, so I wanted to see what size and thread, bolt I should get to fix it?
    • By AaronD1982
      Next problem with charging system to tackle, any help would be appreciated.
      New starter solenoid....check
      New Voltage Regulator...check.
      Dynamic test to Stator.....bang...pulling like 2 Volts AC
      Problem: Without pulling the part out and stranding the vehicle at the shop forever.... I am trying to find the correct stator or at least one that might not be exact for the Massimo Buck 400S, but fit and connect and do the job if that makes sense.... if anyone has any ideas, please shoot them my way.
    • By Mitch13
      2022 Coleman 400 with 13 hours on the engine and the mice got to it. Every wire coming out of the steering column in one cluster has been eaten through. I tried reconnecting matching wire colors to each other and I get the left turn signal and hazards to work, nothing else. If I play around a bit I can get the horn to honk or headlights to come on but only when I connect them to the brown wire. Obviously I don't know what I am doing here. Does anyone have a picture of how these wires are connected when they are under the hood on the drivers side coming from the steering column?
      Gray - seems to carry power
      Brown - left turn signal
      Pink with red stripe - horn?
      Green - head lights?
      Yellow - head lights?
      Yellow with red stripe?
      Blue?
      Dark green?
    • By AaronD1982
      I recently purchased a 2019 or 2020 (no manual) Massimo 400S Buck Series UTV.  It ran fine for a couple days but the low battery light was flashing while it drove.  It then died in the field one day and I was able to jump the battery and get it rolling enough to get back to the barn.  It started both times I turned the key for a couple days after and when driven died 10 minutes later in the driveway.  Even after jumping it had no juice, but with the key out of the ignition it kept trying to start, a quick look on the Google machine and it suggested starter solenoid or ignition switch was the culprit.  Fair enough, let's just order a replacement solenoid, right?  No way Jose....the pin connector on the UTV is a 2-pin white plastic connector and the part received is a 4 pin.  How do I swap that and make it work?  Can I even?  Where do I find correct parts in the future?
