GENERIC COIL OVERS OR STRUTS
I have a 2013 Intimidator, which The first year it was produced. They are made in Arkansas and at one time we’re connected to the Bad Boy Company someway.  Mine has a 747 cc Kohler engine. It is probably the same size as a Polaris or other buggies with comparable power.
Does anyone know it there are companies who sell generic shocks/struts for buggies.
Link to comment
Share on other sites
There are, but a vast majority come from China.
if there is a problem with the current shocks, broke or just flat out wore out,
I 'd  replace them with O EM  parts.  If you do get an aftermarket shock, if they're springier than the original your bed load capacity could be reduced
Link to comment
 Share
    • By GRAYWHISKERS
      So my engine was locked up. Pulled flywheel and found alot of mud and the magnets broken. Anyone else have the magnets break?
    • By Green Scout
      Hello everyone.
      Here I am showing our Green Scout electric all-terrain vehicle.
      All-terrain vehicle 6 wheeled, electric, side-turning. Rides, jumps, dances, swims, but does not fly. The drive is permanent (but you can turn off any wheel arbitrarily through the controller). The power of each wheel is 3 kW at its peak, the total power is 18 kW. Speed up to 60 km / h. Since the all-terrain vehicle is electric, it starts from a place quickly, drives silently (well, of course, the sound from tires and shock absorbers does not disappear).
      The idea of creating such an all-terrain vehicle came after the experience of operating the Argo all-terrain vehicle. The main disadvantages of the wheeled side-turning all-terrain vehicle are low ground clearance, lack of suspension. To get high ground clearance and suspension, there are two outputs on mini all-terrain vehicles - either electric drive or hydraulic. The hydraulics had to be excluded, since at temperatures below -30C it does not work, plus it always flows. As a result, we settled on an electric transmission. Each wheel is a motor-wheel. Naturally, the motor-wheels were being finalized to be able to be installed on an all-terrain vehicle and to be able to swim. The battery is iron-phosphate, all information on the battery, the charge is displayed on the smartphone. Control of the all-terrain vehicle through the on-board computer. Bicycle handlebar controls. Braking either with the sides through a turn of the steering wheel, or with the gas pedal of all wheels at once.
      Overview video of the all-terrain vehicle
    • By Ducks
      All,
      Have been looking into going the electric route.  Currently have Deere and Kawasaki UTV's we use at our duck club. We've been thinking about going electric due to noticeable disturbance to the birds caused by engine noise. Anyway, it seems that the forums are somewhat devoid of Intimidator discussions regarding the good, bad and the ugly.  Wanted to put this out there.  I have also looked into the Polaris EV and have located one here in Missouri.
      Just an open question.  I'd love to hear about anyone's experience with the electric Intimidator or the Polaris for that matter.
    • By Robby
      Hello, I have a 2013 500 utv hisun. Was running ok and cut out while parked. Bike will not start now. It turns over, but won't fire. I have no spark and no fuel. I replaced fuel pump, ignition coil, spark plug, cdi, voltage rectifier and all the fuses and relays. Could bad stater cause no fuel because I can't hear the fuel pump priming. Any info on where to start looking for problem.
    • eManualOnline
    • By johnpeter
      2016 Polaris RZR Turbo XP4 Cage, Winch, Tons of upgrades  On Ebay
      https://www.ebay.com/itm/294427422202?
