  • Similar Forum Topics
    • Wanted: Trooper Axle Parts
      I am interested in any old trooper axle parts you may have lying around. Please let me know if your want to sell them.  Backstory: Hey everyone. Last trip out to moab I climbed a wall on poison spyder Mesa while 2 rzr xp1000's and three can am x3 xrc's watched me and didn't dare try. After doing it once I pulled around to show them it wasn't a fluke. One on the can am x3 xrc drivers just looked at me and said "that's steep". On the second try I spread the bell on the left rear axle. I made the climb but now the inner cage slips inside making a loud popping noise as twisting the boot. I mainly just need the inner bell but I am interested in anything you have.
      By 2scoops, in Joyner UTV SxS Forum
      • 1 reply
      • 236 views
    • 2009 Joyner trooper fueling problem
      Fuel pump runs but nothing is getting tô it. I tried putting a vacuum on the outlet hose of pump and it wouldn't pull anything. This machine sat for a year and a half unused. Is there a way to prime the lines?  What could be the cause of the fuel not getting tô the pump?
      By Whisper Snowbird, in Joyner UTV SxS Forum
      • 4 replies
      • 118 views
    • 2009 Joyner trooper valve adjustment
      I need to adjust my valves. But I can't find any specs that tell me the valve clearance. Can someone help me?  1100cc chery
      • 8 replies
      • 111 views
    • 2009 Joyner trooper starting problems
      I have a no cranking issue with my joyner. It has a chery 1100. It will click but nothing after that.  New battery. I tried banging in the starter while holding key in start(old car trick). Now the  starter solenoid won't even clunk. Just hear s click fron the relay now.  My assumption is the starter needs replacing.  Any ideas of other things to check? Does anyone have diese block diagrams?  Got no clue what fuse or relay goes to what
      • 12 replies
      • 177 views
    • Trooper 1100 Turbo Kit?
      Hey guys, so i have built my own turbo kit in house and it works awesome! seeing these turbo kits for sale for 3 and 4k seemed a little steep for me.. i built my entire kit intercooled and all for less then half of that price so i am considering selling these kits.. if i could produce a complete bolt on kit that could be installed with simple hand tools in your garage strait for $1800 and intercooled for $2500 would any of you be inerested? i would like to post pics but not sure how to? i have also snorkled my trooper and not just the air filter but diff vents, the two chrome catch cans (crankcase vent and radiator vent) along with raising the ECM and fuse boxes to head level.. this as well could be sold as a kitfor very little cost. i can also do the work in-house if needed (install all of this for you) for only a couple of hundred... is this stuff you guys would be interested in? Turbo kits will be complete al the way down to an Autometer Vac/Boost guage, fuel controller etc.... i have seen a HUGE increse in power! if you have more questions you can call me at 713-824-8891 i'm in the Houston Texas area. Also Lenny would you mind calling me so i could pic your brain for a min? some questions about this site (how to post pics, stetting up my profile etc.) as well as a few other things. Thanks i love this forum and really look foward to helping in the future! and really like seeing extreme joyners on the trail!
      By goindeep, in Joyner UTV SxS Forum
      • 16 replies
      • 6,275 views
