What do you do when
  • Replies 485
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
So how can i fix my UTV? " we'll circle back"
Better make a bunch. They may need to double or triple the masks.
I heard that too--it was just a whiie back on  one of those "I can't believe people can possibly get any stupider." days--kind of like November 4, 2020. Though in this one I'm not sure to whom th
Posted Images
21 minutes ago, Joe Breaux said:
Oh, didnt you hear? The CANCEL Culture has now been CANCELLED !!  lol  Too many cancellations..
that would be nice.
Link to post
Share on other sites
Acted up some again today....
 so while i held the key in start, i kind of fumbled around with the ignition switch wires, on the Wiring harness side plug (female connectors which im about to replace) and i got one of the wires in a certain position once and it cranked over, but i couldn't get it to do it again. but where the plug in is, you have to have small hands to get to it.... maybe i need to fly someone from Kawasaki over here to reach back in there.
Link to post
20210413_190338.thumb.jpg.82b496eee2b0a6db53ab53913bdafc61.jpgYou can see obvious corrosion in the top right terminal
 That is where the white wire, which is fused and carries power from the battery to the keyswitch.
I did a resistance test on that 1 terminal, some instances it would show 0 resistance, and if i moved it some it it would vary from 3 to 9ohms , and a few times no continuity at all.
Link to post
Here's what it looks like now, I put dielectric grease where the wire goes into the crimp terminal. I ran out and I want to put some on the blade connectors themselves. Then heatshrink each individual wire.
I also may try to find a big piece of heatshrink to seal this whole unit.
Link to post
34 minutes ago, Travis said:
Heh, never knew crimping the end of those would help hold.
Learn something new everyday.
It was new to me less than a year ago--didn't know that plastic could be crimped...
Link to post
Went to o'reilly's and got some dielectric grease, i went ahead and cut off the plastic connector from the new  Chinese ignition switch, since the same corroding can and will happen in it anyway, so i got some quick disconnects and plugged each wire in individually,  also greased the wire where it crimps and where the 2 connectors connect. and then put some waterproof heatshrink over each connection and wrapped it in electrical tape tightly to "dress" it up a little bit.
Link to post
3 minutes ago, cliffyk said:
It looks good--I think you accomplished a lot of improvement!
and hopefully a fix.
still mad at  joe breaux, he never brought the duct tape :lol: :D
Link to post
8 minutes ago, Joe Breaux said:
got it right here buddy ... but streets are flooded here , got 6 inches of rain in one afternoon,  cant get out unless I crank up the AIRBOAT ..
Airboat ain't made by massimo, is it? LOL ;)
Link to post
Well darn.
after doing the ignition plug in's all nice and pretty and the plugs for the  circuit relay, i went this evening, turn the key, Click. turn the key, Click,, turn the key, Click. Turn the key, VROOM, starts right up.
 It then occured to me one connection i had neglected to change was the one that goes back to the neutral safety switch on the trans. looking at the wiring diagram, my interpretation is it acts like a ground for the starting circuit. so i cleaned it up, and put a new ring terminal on it.
we'll see.....
Link to post
