now what?
Joe Breaux
well, with motor cover off,  riding in the bed, theres so much noise going down the trail that I cant hear the whining  ,so I cant isolate it with a hose .. Put cover back on, theres the whine again... I give up.. let it break.. Then I will know what it was... but it is still running very well.. new adjustable temp fan control switch working good. engine stays cool
Link to comment
Share on other sites
1 hour ago, Joe Breaux said:
noise still there, but damn thing is running great..  no issues ...new adjustable temp fan control works perfectly..   temp is in a safe range all the time now.   . hopefully it will continue
I've got 6.5HP briggs mower with a connecting rod chirp/rattle. It's been doing that for 7 or 8 years. Some times stuff will make noise and never break.. Then something that sounds good breaks just like that.
Link to comment
  • 5 months later...
Not sure if this is along the same lines but hoping someone can answer. I have the 2017 MSU utv 500 and with moving shifter with ease I get nothing on the indicator as if nothings changing. Also as far as the indicator says it’s stuck in H and when trying to drive it revs high barley budges like it wants to go but doesn’t. Can anyone help with a solution? Adjusted the linkage and took it apart to check the teeth and everything looked fine on it. Also took the cover off to see the clutch and belt but without fully taking everything apart the only thing I noticed was the belt seemed to big to sit in the groove properly and rubbed on the cover. But doubt that is the problem so any help or ideas much appreciated, thank you!
Link to comment
    • By Robert B
      Going down a 20 deg hill engine is holding UTV back. Then something releases like going into Neutral and makes a loud clacking noise. Have to use brake to slow UTV down. Then once level it shifts back into gear. Have done shift extension does not pop out of gear.
    • By AlphaSerenity
      Hello,
    • By LindaCall60
      Purchased a 2011 bighorn banchee. Needs motor work. Not sure what. Husband is mechanic but not computer savvy. So, is there a manual that will tell him how to tear this down?  We have down loaded a service manual, but he says it doesn't tell him what he is looking for.
    • By KMart
      I have a Massimo 400 Buck that overheats and the antifreeze blows out of the motor everywhere! I don’t have to be doing anything but just driving through the field.  It only has 26 miles on it.  I don’t think the fan is turning to cool the motor.  Any ideas how to fix this?
    • By KMart
      Has anyone ever had a Massimo 400 Buck that overheats and the antifreeze blows out of the motor everywhere?  I don’t think the fan is turning to cool the motor.  Any ideas how to fix this?
