Starting
By malenurse13
We just bought a used 2017 American Landmaster TW450. No hour meter that I can find, so not sure exactly how much it has been used.
The first 2 days we had it, the starter was a little sketchy, but it started after 2-3 tries. Sometimes when turning the key, we would hear a loud metal "clink" sound. Like the starter made contact, but didn't have enough power to turn.
THIS MORNING... Turning the key, we hear a single click sound. That's it. Even with a new battery, the starter is still doing the same thing. Both batteries (old and new) were reading 12.8 volts on volt meter. So I'm wondering what else could be going on? Any ideas on what to look for would be greatly appreciated...
Thank you!
By packersfan
I have a hisun 500 got from a auction and when turning a corner left or right it's a two hand job then when you left go snaps back.any help on what to look at would be appreciated.
Also blows blue smoke until she gets warm then it's ok
By DJ Brusenski
checked all the fuses and relays, I can jump start it with the key in the on position. it will not key start need some help, thanks
By Dave N.
2020 Massimo Buck 400 - Won't start. Can hear the starter spinning, but motor never turns. Relay? Starter? Worked fine one day and not the next. Thanks for any help you can provide.
By Bassarino51
My 2014 Odes with less than 1000 miles suddenly won’t turn over with a fully charged battery.
