Massimo Buck Check Engine Light
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
By malenurse13
We just bought a used 2017 American Landmaster TW450. No hour meter that I can find, so not sure exactly how much it has been used.
The first 2 days we had it, the starter was a little sketchy, but it started after 2-3 tries. Sometimes when turning the key, we would hear a loud metal "clink" sound. Like the starter made contact, but didn't have enough power to turn.
THIS MORNING... Turning the key, we hear a single click sound. That's it. Even with a new battery, the starter is still doing the same thing. Both batteries (old and new) were reading 12.8 volts on volt meter. So I'm wondering what else could be going on? Any ideas on what to look for would be greatly appreciated...
Thank you!
By KMart
I have a Massimo 400 Buck that overheats and the antifreeze blows out of the motor everywhere! I don’t have to be doing anything but just driving through the field. It only has 26 miles on it. I don’t think the fan is turning to cool the motor. Any ideas how to fix this?
By DJ Brusenski
checked all the fuses and relays, I can jump start it with the key in the on position. it will not key start need some help, thanks
By KMart
Has anyone ever had a Massimo 400 Buck that overheats and the antifreeze blows out of the motor everywhere? I don’t think the fan is turning to cool the motor. Any ideas how to fix this?
